Timing jumps all over the place. '88 YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Timing jumps all over the place. '88 YJ
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 09-21-2013, 03:57 PM   #1
Maine1994ZJ
Tried to set the timing in my '88 258 YJ. the timing mark was jumping all over the place.
Bad distributor or worn out timing chain?
'93 V8 ZJ Mountain Goat Edition.
Maine1994ZJ is offline   Reply With Quote
Unread 09-21-2013, 04:24 PM   #2
Old4X
1990 CJ7
Yes
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
Unread 09-21-2013, 04:44 PM   #3
dancytron
Have you done the Nutter bypass yet? If not, it could be the computer going crazy from a bad sensor or otherwise. Mine did that before I did the Nutter bypass, I suspect from a bad knock sensor.
dancytron is offline   Reply With Quote
Unread 09-21-2013, 05:58 PM   #4
Maine1994ZJ
I'll investigate that. Thanks
Unread 09-21-2013, 06:06 PM   #5
Mean Max
Don't poke the bear
Mean Max's Avatar
Timing chain.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 09-22-2013, 05:44 AM   #6
WDNewman
Originally Posted by Mean Max View Post
Timing chain.
Max
Ditto.
WDNewman is offline   Reply With Quote
Unread 09-22-2013, 09:54 AM   #7
Maine1994ZJ
Thanks all!! I'm going out do do the Nutter bypass right now.... Because I have all the stuff I need to do it so, it's free.
If the timing mark is still jumping all over the place then I'll investigate the timing chain.
Really hope it's not the timing chain.... this sucker only has 120K miles on it..
I'm guessing the ported vacuum on a weber is still by the choke on the valve cover side?
Unread 09-22-2013, 12:05 PM   #8
Maine1994ZJ
So, I just finished the Nutter Bypass.
What a difference!!!!
No jumping timing mark, it runs WAY smoother than it did! It still sputters a little at idle, however.
I can't believe the power difference, except 4th gear which is pretty boggy, and 5th gear which just causes serious detonation and loses speed.
Would this be a vacuum leak, or do I need to Team Rush it, or both?
Or possibly some other gremlin I'm not aware of?
