Timing issue - JeepForum.com
post #1 of 13 Old 01-19-2014, 12:45 PM Thread Starter
Sgtrhoads
Timing issue
I am having a hell of a time getting my rebuilt 95 4.0L to start. I rebuilt it before I deployed last year and have just got back home to work on it again. I have timed the cam multiple times. The new chain set I received is a 64 pin set. I can't find the old one to see if it was 64 or 48 pins. I have check the distributor timing many times as well. It is continually back firing through the throttle body. I can't seem to figure this out. Any help would be greatly appreciated!!
Sgtrhoads is offline
post #2 of 13 Old 01-19-2014, 01:07 PM
Mark05059
lets start at finding TDC on the intake stroke.. pull #1 plug wire. Turn the crank over using the crank bolt at the front of the motor while sticking your thumb over the hole.. When you feel pressure on it stop and put something skinny and long (screw driver, wooden dowel) into the spark plug hole and turn slowly till it stops moving. Remove the cap and see if the rotor is pointing at #1 on the cap. If it all looks correct then you may have to double check your timing marks.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 13 Old 01-19-2014, 01:21 PM
GrEmLiN
1987 YJ Wrangler
Mark beat me to the punch. Couldn't have said it better.
Verify TDC before anything else. If that checks out, check timing marks. Somethings not right.
GrEmLiN is offline
post #4 of 13 Old 01-19-2014, 01:25 PM Thread Starter
Sgtrhoads
I verified TDC when installed the timing set. The book states 15 pins from mark to mark when the cam timing pin is at the 2 o'clock position. This is for a 48 pin chain, where I have a 64 pin chain so the check doesn't work. With the #1 at TDC, the timing marks point at each other. The distributor rotor is pointing at the #1 cap point. Just to verify, the #1 should be at 5 o'clock when standing on the passenger side of the engine, correct?
post #5 of 13 Old 01-19-2014, 01:52 PM
jsawduste
2006 YJ Wrangler
180 off. Turn the crank 1 revolution and reinstall distributor.
jsawduste is offline
post #6 of 13 Old 01-19-2014, 03:17 PM Thread Starter
Sgtrhoads
When I did the the rotor points at the #6 firing position when at TDC.
post #7 of 13 Old 01-19-2014, 03:18 PM Thread Starter
Sgtrhoads
Does anyone know the correct timing chain for a 1995 4.0L? Either 64 or 48 pin chain
post #8 of 13 Old 01-19-2014, 03:48 PM
jsawduste
2006 YJ Wrangler
As it should have. Now move the dist. back to #1 without touching the crankshaft. Turn key and hear engine run.
Guessing you have the plug wires arranged in the firing order, correct ?
post #9 of 13 Old 01-19-2014, 04:00 PM Thread Starter
Sgtrhoads
I do but you have me confused. I can't turn the distributor due to the mount bracket. It can only go in one way
post #10 of 13 Old 01-19-2014, 04:13 PM
jsawduste
2006 YJ Wrangler
Take the hold down off. Raise up dizzy and rotate the rotor back to #1 firing position. Lower dizzy and tighten hold down. Remember the cam gear is helical cut so as you raise and lower the rotor will turn a touch.
post #11 of 13 Old 01-19-2014, 04:42 PM
Mark05059
or you can cheat just to be sure without removing the distributor.. Put #1 plug wire where the rotor points (#6 hole) and finish the firing order.. the motor should run.. when
it does then your 180 out and should move the distributor to the correct position
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #12 of 13 Old 01-19-2014, 05:24 PM
jsawduste
2006 YJ Wrangler
Indeed Mark but I did not want to add any more confusion.
If the 180 doesn't work then I`ll bet he is a tooth off cause of the rotation when the dist. gets dropped back in. Happens to all of us.
post #13 of 13 Old 01-19-2014, 06:05 PM Thread Starter
Sgtrhoads
Thanks I'll try that tomorrow
