Quantcast Timing help! Replaced timing chain now I can't get the timing right. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Timing help! Replaced timing chain now I can't get the timing right.
Old 01-20-2009, 09:06 PM   #1
yjcrawlr
I recently had some timing issues and turned out the timing chain had wore a few teeth off the cam gear. Lined up the dots counted the 15 pins and put it all back together with a new chain and gears. Now the best I can do is some pops and bangs coming out of the carb. This is not my first time timing a engine. It is my first inline six. I have timed 4cyl and v8s with no problems. I have found tdc (so I thought) at least a few times. I have tried to time it by watching the lifters and I don't completly understand how to do this method. I have put my finger over #1 while cycling the engine and after the long suction I get a smaller puff of air out the plug hole which is what I thought was tdc. This is were the timing sits now banging and popping when you turn the engine over. I have tried a tooth each way from there and then put it back to that spot again. At one point in the engines cycle I get a huge puff of air out #1, I was told this is not tdc. Each time I have been lining the timing marks on the balancer with 0 and Pointing the rotor at #1. Is it possible something got damaged when I was turning the engine over while the timing was out(timing chain slipped). Help please before I start tearing the motor down.
Selby
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
yjcrawlr is offline   Reply With Quote
Old 01-20-2009, 09:09 PM   #2
Opihi59
from here it gets rough
Opihi59's Avatar
Is it possible you're is 180* out? (meaning you're at TDC, but for exhaust, not compression) I've done this before in a 4 cyl
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm
My Boy Scout Troop site: http://t-304.blogspot.com/
Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done.
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Opihi59 is online now   Reply With Quote
Old 01-20-2009, 09:44 PM   #3
yjcrawlr
I have considered the 180 out and flipped the distributor 180 several times. I also get some high pitched squeals some times when the engine is turning over, I am not sure if it is the belt or something internal, I checked the alternator and other pulleys not them sqeaking.
Old 01-20-2009, 11:28 PM   #4
jbolty
ISO 9001 Compliant
jbolty's Avatar
you might have the valve timing out 180. You can tell which is the exhust and intake valve by looking at the positions of the manifold inlets. Turn the motor and watch those two valve rockers go up and down for the intake stroke, then compression stroke, then power stroke, then exhust. For the compression stroke they should both be closed. TDC there is what you must have to get the valves or the ignition timed. Also, make sure you are looking at the right marks. Sometimes the sprockets have marks that look like they should be the timing makes but are not. Normally the proper marks are close to the edge.
Originally Posted by Stimpdezracer View Post
Cross threading is as good as lock-tite
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Old 01-21-2009, 01:05 AM   #5
Pittsbuilder
Verify TDC #1 by inserting a screwdriver or something into the spark plug hole, and slowly turning the engine until the screwdriver stops. There should be several degrees of crank rotation where the screwdriver wont move at all. Split the difference between where it stops ascending and starts descending. thats TDC. Also, verify that both valves are closed during this stroke. Once this is complete, check your dizzy position, and give it a try. If that doesnt work, your problem problem most likely lies in the cam timing. Make sure the cam is indicating TDC when the #1 piston is at TDC. DON'T trust the mark on the balancer, until you have verified it using the method listed above. They have been known to be off in the past
Pittsbuilder is offline   Reply With Quote
Old 01-21-2009, 06:47 AM   #6
sitdwnandhngon
1987 YJ Wrangler
That happened to me too. It was easy to fix but left me confused as hell for hours. I would rotating one of the gears one turn.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline   Reply With Quote
Old 01-21-2009, 07:48 AM   #7
yjcrawlr
when I watch the rockers for the valves they both go up and down(two at the front), at no time are they both down at the same time. If the dots on the timing gears line up and I have the 15 pins between them with the cam gear at 1:00 can the timing gears be out 180? If so help me understand how to get it right.
Old 01-21-2009, 09:01 AM   #8
sitdwnandhngon
1987 YJ Wrangler
If thats the problem the way to fix it is to take the chain off, rotate the cam gear one full turn and then line the dots back up and put the chain on.
4.2 has 0.2 more!
Old 01-21-2009, 09:04 AM   #9
Alexsdad
with the above.
My Son's Wrangler (I wrench it)
1994 2.5L AX-5
Alexsdad is offline   Reply With Quote
Old 03-11-2010, 07:49 PM   #10
chato77
hey buddy i have a better technique for the timing..
hey selby i know that your timing is getting on your last nerve but i have a solution for you buddy i learned this from my uncle master mechanic oh and his mexican so that trick
is from his old country and let me tell you it works .ok first thing you do is take out the #1 PLUG&WIRE get a plastic bag and tear a small piece then ball it up then gently push the plastic inside then you have your friend give it a click when you see that plastic ball fly out with pressure then you get a thin flat head screwdriver shove it in there then your friend again will give a few clicks till you hit tdc you will sense the piston at the very top thats when you know your there wish you luck.....
chato77 is offline   Reply With Quote
Old 03-11-2010, 08:19 PM   #11
Mark05059
personally.. I wouldnt put anything "loose" in my motor.. just remove plug 1.. hold your finger over the hole... when you feel pressure then start using a screw driver. Makes it easier if you use a wratchet and socket on the crank bolt to turn it
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote
Old 03-11-2010, 08:52 PM   #12
Larry93
Larry93's Avatar
TDC happens every rotation of the crank so setting your #1 cylinder is of no issue. The cam rotates at half the crank speed so your TDC is really when the piston is at the peak of its up stroke and the cam lobes for both valves are at base circle. The valve cover off is a must when you set the timing, you can clearly watch the rockers movement in relation to the crank then. You know when you have both valves on the base circle when the rockers are slack on the valves and you can twist your push rods with your fingers.
Larry93 is online now   Reply With Quote
Old 03-11-2010, 09:08 PM   #13
Opihi59
Opihi59's Avatar
Cam rotates at 2X the crank speed...
Old 03-11-2010, 09:11 PM   #14
Larry93
Larry93's Avatar
No it is half the speed, if it was twice engines would not run to long.
Old 03-11-2010, 09:12 PM   #15
Opihi59
Opihi59's Avatar
Wait, now I'm confused.......I know this is gonna set off a firestorm. I think you're right since I read a few posts and did a google. I will have to get back on this one. I may be a total bozo. Please be gentle with me.
Glock Forum
