timing and compression on 93 2.5L - Page 2 - JeepForum.com
post #16 of 16 Old 04-07-2010, 04:27 PM Thread Starter
myoldjeep
Replaced distributor - fixed problem.
I couldn't tell you if it was the pickup coil, or worn gear, or worn bearing, but it's fixed now.
myoldjeep is offline
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 09:36 AM
What should my compression be? 2.5l tawdr77 YJ Wrangler Technical Forum 18 01-18-2010 12:27 PM
low compression cyl 1 wanabejeeper YJ Wrangler Technical Forum 7 09-21-2009 05:42 PM
Full compression in front, no compression in rear Caceman YJ Wrangler Technical Forum 5 05-20-2009 08:00 PM
Compression ? Zazoos YJ Wrangler Technical Forum 6 08-03-2007 07:33 AM
