Timing Chain Time - JeepForum.com
post #1 of 7 Old 06-19-2011, 03:31 PM Thread Starter
Jakers09
Timing Chain Time
So I've got about 165k on the 4.0 and I know I have a few issues to tackle.
The first thing I know needs to be corrected is the rubber on the harmonic balancer is coming out. As long as I'm in there, I'm thinking I should go ahead and replace the timing chain.
So here are the questions:
1. If I'm replacing the timing chain, should I go ahead and replace the sprockets as well? That is, should I purchase the whole set or just the chain.
2. I've read where you don't have to remove the oil pan in order to to do the timing chain - however, as long as I'm messy, should I go ahead and do the seal on the pan?
2a. If I'm going to do the oil pan, should I just go ahead and do the oil pump?
2b. If I'm going to do the oil pan, should I just go ahead and attempt the rear main seal? It might be leaking, but it might be the oil pan/valve cover.
3. Lastly, if I'm going to have the bottom off the motor, obviously going to inspect everything... Should I go ahead and re-do the gasket on the valve cover and inspect the topside. (btw, I'm a noob so I'll probably just say "wow, looks cool" and put everything back together...)
Any suggestions on parts sourcing and part numbers will be helpful. Also, beside the harmonic balancer puller and the pullers for the timing chain, are there any other special tools I'll need to rent?
FYI, I've got O'Reilly and Napa local.
1991 YJ 4.0 | NP231 | AX15 | Dana 30/35 | Front Locker | Tom Woods DS | M.O.R.E. SRS
2003 TJ 4.0 | STOCK X
Our favorite game is 'SMACK A JEEP' - started off as a way for my buddy to get even with his girlfriend's slug-bug fetish. Simply smack her in the face as hard as you can when you see a Jeep Wrangler and yell, 'SMACK A JEEP!!!!'
Never actually smacked anybody, but my kids LOVE the game. Now my whole family plays it - and so do my kids' friends!
Jakers09 is offline
post #2 of 7 Old 06-19-2011, 03:36 PM
SimplyTron
I get the sprockets too, its only a little extra and you already have it apart. I did mine on my 2.5 and I didn't have to take the oil pan off just had to loosen the front 4(?) bolts.
SimplyTron is offline
post #3 of 7 Old 06-19-2011, 05:10 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Get the timing chain SET. This will include new sprockets along with the chain.
As far as everything else goes, it's up to you. If it is leaking oil etc, then by all means fix it.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 7 Old 06-20-2011, 08:21 AM
YJ-Jer
Pan gasket replacement will depend on the condition of the gasket where it meets the timing cover. I had already replaced mine with the one piece Fel-pro one so there was no need. Had it been the original, I would have just replaced the pan one too since it just crumbled when I removed it the first time. If you do drop the pan, I would definitely replace the rear main seal as it is easy to do and you already have the pan out of the way. I did not replace my oil pump as it is still putting out 35-40 at idle. Make sure you get the one piece pan gasket. I would also do the valve cover as they are notorious leakers and the crank ventilation orifice likely needs to be cleaned.
Have fun!
-Jerry
Originally Posted by unknown
"You know you drive a YJ when you run over a shadow and feel the steering wheel jerk."
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJ-Jer is offline
post #5 of 7 Old 06-20-2011, 08:30 AM
1tuffyj
^this^
I did my 2.5l timing set not long ago. Got all parts from rockauto. The gasket that comes with it is junk. DONT use it. Its supposed to mate w ur stock oil pan gasket but it don't. Get a new oil pan gasket (so its all 1 pc) n drop the pan w the timing cover. As far as the rest I've always been told don't touch the rear main unless its leaking. Just fyi its a 2pc seal n not as easy as u may think to replace.
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #6 of 7 Old 06-20-2011, 11:15 AM
kahanabob
like 1tuffyj says the rear main seal can turn into a goatrope. if it ain't broke don't fix it.
kahanabob is offline
post #7 of 7 Old 06-20-2011, 04:11 PM
plym49
Always replace the chain and the sprockets. Chances are your original cam gear is toast, anyway: you'll see.
Absolutely replace the rear main seal while you are in there. It is not hard, and you are going to have to to it eventually anyway. Pulling the pan is the hardest part, and you have to do that anyway if you are changing the timing chain.
Don't lose or forget the spacers on the timing cover and don't lose or forget to reinstall the cam tensioner spring and plunger.
plym49 is offline
2.5 Timing chain/cam timing issue csock YJ Wrangler Technical Forum 6 06-14-2011 09:58 PM
Timing Chain? Blackfish YJ Wrangler Technical Forum 3 06-20-2010 11:29 AM
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 09:36 AM
Possible Timing Chain? SwearingYeti YJ Wrangler Technical Forum 3 01-09-2007 02:22 AM
When to seriously think about the timing chain FL 4.0L TJ Wrangler Technical Forum 12 02-26-2006 10:02 PM
