Quantcast Timing Chain! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Timing Chain!
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-22-2006, 08:15 PM   #1
Josephrk24
Timing Chain!
Time to do the timing chain after looking at it while doing my RM....
I love my jeep!
Any tips or pointers?
Thanks Joe.
1990 YJ I6 258 AX-15 NP 231 *Now with Posi-Lok*
5 Inch BDS Lift
33X13.50 Mickey Thompson BaJa Claws
Early YJ club member #29
Josephrk24 is offline   Reply With Quote
Old 12-22-2006, 11:15 PM   #2
daaaaaan
just ripped mine apart today to find out I needed a new one bad...there was about a 1/4" play in mine, and the tensioner was "unlocked" and wouldnt re-lock so that meant it was broken....
No real tips, just take off the fan/shroud/altenator (makes things a lot easier)....use a puller to take off the crankshaft pulley (its press fit on after you take off the main bolt and washer) also, dont forget to take off the 3 bolts that are located underneath the timing cover (these keep the front of the oil pan on)....then when you see the 2 timing gears, crank them so the 2 "marks" are lined up so when you put the new chain on, it is easy to calibrate it.
I would suggest replacing the tensioner & bumper while youre in there (along with all the gaskets)
Any questions feel free to ask......
2012 Overland 5.7L
daaaaaan is offline   Reply With Quote
Old 12-23-2006, 01:37 AM   #3
sequel
Maybe do the water pump while you are in there.
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline   Reply With Quote
Old 12-23-2006, 08:26 AM   #4
jeepin1995
jeepin1995's Avatar
X2..... even if it ain't leaking..... better to do it while it's apart then do it all over again. i did mine in reverse tho...... water pump needed replacing, so i threw a timing chain in there whils i was at it.....
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Glock Forum
