Timing Chain? - JeepForum.com
post #1 of 4 Old 06-20-2010, 09:12 AM Thread Starter
Blackfish
Timing Chain?
Engine Noise
I have had a increase in a knock in the bottom front of the 2.5l so I have removed the timing chain cover to look for wear, have a few questions before I purchase the kit.
1. The Chain has about 3/4 of an inch of play on the buffer side is this to much?
2. The buffer has 2 groves worn in it that appear to be the drag tracks of the chain they are 1/8 of an inch deep is this normal?
3. could the harmonic damper be clogged with dirt and create a wobble that could have caused this an other damage?
4. Can I put the harmonic damper on without the cover and run for a short period to see if the chain was causing the noise?
Help requested,
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
post #2 of 4 Old 06-20-2010, 09:28 AM
Brown Dog
Vendor
Brown Dog's Avatar
I believe the chain is worn pretty badly, and no further diagnosis is necessary.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 4 Old 06-20-2010, 09:45 AM
moonshinefuel
If it were mine I would change out the timing chain, gears, tensioner, guide, the whole timing chain replacement kit. Also, I would not start it with the timing chain cover off. I don't think dirt clogged in the balancer is causing this no. The grooves and play in the chain are telling you it's a great time right now to replace it. Not advisable to wait any longer. Can't say for sure if it is the cause of the knock, but at least you won't get stranded from a broken timing chain.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 4 Old 06-20-2010, 10:29 AM Thread Starter
Blackfish
Thanks for the help as I was cleaning up the harmonic damper I noticed that the shaft on it was worn where it contacts the cover seal also the harmonic damper was full of dirt between the spokes about a 1/2 a cup of dirt, I have ordered the whole kit, any other help would be welcomed.
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
Timing Chain? Sambox YJ Wrangler Technical Forum 11 11-21-2008 04:49 PM
timing chain JRocker TJ Wrangler Technical Forum 2 12-16-2007 04:48 PM
Can a 4.0 timing chain set be used on a 4.2? rollerized YJ Wrangler Technical Forum 5 05-15-2007 07:55 PM
Help On Timing Chain NYCjeep YJ Wrangler Technical Forum 1 02-01-2006 04:31 PM
