Timing after Nutter-What am I doing wrong? - Page 2 - JeepForum.com
post #16 of 56 Old 11-13-2011, 01:31 PM Thread Starter
copleydad
copleydad's Avatar
Great. The starter is clicking. Couple hammer whacks got her going.
WHERE DOES IT END? Guess its an online shopping night while watching the Pats
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #17 of 56 Old 11-13-2011, 01:40 PM
jeep108
Geez that dog carries a big stick.........
Have you ever pulled the distributor and the #1 spark plug and found tdc? There is a good write up on here somewhere.
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #18 of 56 Old 11-13-2011, 03:45 PM Thread Starter
copleydad
copleydad's Avatar
Yeah he does. Here's the "stick" when he pulled it out of the woods last weekend. He's whittled it down a bit
And no, never done that. Think you mean dist cap, but I am pretty sure timing is there now. Wonder If maybe its crappy gas? Hell, could be a hundred things I guess.
post #19 of 56 Old 11-14-2011, 02:58 AM
dodger889
You asked about the coil they could become weak over time and show up as a miss. If you still have a stock coil what are your plugs gaped setting. If I remember right they should be at .025
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #20 of 56 Old 11-14-2011, 04:29 AM Thread Starter
copleydad
copleydad's Avatar
I do still have the original coil, and new plugs gapped at .035.
Coil's like $30 or so. Gonna see about picking one up. The coil and distributor are the only old links in the chain.
post #21 of 56 Old 11-14-2011, 11:35 PM
jeep108
Thats funny
No i mean actually pulling the distributor to ensure your at top dead center and that your distributor is installed correctly. Post #9 of the below thread is what prompted me to do this.
http://www.jeepforum.com/forum/f12/f...enter-1175664/
jeep108 is offline
post #22 of 56 Old 11-15-2011, 05:43 AM
dodger889
On his he does not really need to do with this has long as the timing order is correct for the engine, number one plug wire is where the rotor is pointing for when the number 1 cylinder close to tdc on the compression stroke. He has a non fuel injection engine. What you link refers to is for a fuel injection engine. Which has a lot more to do with the firing the spark plug and fuel injection system.
post #23 of 56 Old 11-15-2011, 06:32 AM
jeep108
Finding tdc on my carb'd engine seemed to smooth things out tremendously but maybe it was just a fluke
jeep108 is offline
post #24 of 56 Old 11-15-2011, 02:31 PM Thread Starter
copleydad
copleydad's Avatar
Swapped out the coil today, no change in idle.
There's a guy, Jim Varney, north of where I live who is a race car, hot rod engine specialist, who comes recommended from a neighbor. Called him, explained everything, and he doesn't know what's wrong with it, but is willing to tune the carb and engine, dyno it and set it as best he can for $85. At this point I'm thinking it's the path of least resistance.
I HATE to throw in the towel on this, but can't think of anything else to do.
post #25 of 56 Old 11-15-2011, 04:47 PM
dodger889
Try one last thing first gap your plug to .025 see what happens.
post #26 of 56 Old 11-15-2011, 05:50 PM Thread Starter
copleydad
copleydad's Avatar
What's the idea behind this?
post #27 of 56 Old 11-15-2011, 06:06 PM
oldtime_ironman
A tighter gap is easier for the spark to jump. Lower resistance at the plug, meaning it doesn't need as much volts from the coil.
oldtime_ironman is offline
post #28 of 56 Old 11-15-2011, 07:12 PM Thread Starter
copleydad
copleydad's Avatar
I'm game to try this. I have a set of Champion platinums that I'll regap to .025 and try it out.
I'll let you know
post #29 of 56 Old 11-15-2011, 07:35 PM
oldtime_ironman
I'll let you know
Its well-known that most engines will respond better to a "hotter" spark, which allows for a wider plug gap. If this 025 gap works for you, then it tells me that you could use a hotter aftermarket coil. Accel "supercoil" and MSD "blaster" coil are pretty well-known and established, they usually go for about $50.
I used to run an 065 gap with the HEI, and believe me it made a huge difference. But the stock replacement jeep coil just doesn't have the volts to shove a plug gap that wide. At least, not on a reliable smooth basis.
post #30 of 56 Old 11-16-2011, 07:50 AM Thread Starter
copleydad
copleydad's Avatar
Replaced my regular copper top Champions gapped at .035 with regular copper top Champions gapped at .025, and she looked at me and screamed "HELL NO!". She didn't like that at all. Ran so much rougher, both at idle and with the throttle opened up.
I'm at a loss here. The upside is I know every screw, bolt, nut, vacuum line and wire associated with the carb and ignition. If only one was marked "fix me".
Nutter Timing? JMC51634 YJ Wrangler Technical Forum 4 06-06-2011 08:33 PM
did the nutter, now need help with timing Jblood YJ Wrangler Technical Forum 1 08-24-2008 06:26 PM
Nutter timing ElvisV04290 YJ Wrangler Technical Forum 20 11-25-2007 10:59 PM
nutter gone wrong... VERY WRONG, what happened!??! rolledthatho YJ Wrangler Technical Forum 46 03-31-2007 12:45 PM
Timing with a Nutter natimblue YJ Wrangler Technical Forum 0 11-16-2004 07:46 PM
