Timing a 4.0L - Page 6 - JeepForum.com
post #76 of 80 Old 09-27-2010, 08:33 PM
CJHVN
Thanks Alfons. However I'd hate to start a new thread at this point. There's a lot of really good information here for someone having the same issues.
FYI, I rebuilt the engine before swapping it into my CJ. I have a fear that my "Chevy" buddy might have installed the timing chain incorrectly.
The way I have it set right now, it starts and runs pretty smooth. But even the slightest movement of the distributor will disturb this and it won't run.
I am beginning to think you guys are right about the TPS causing the hesitation. I'm going to test it tomorrow before I go get another one, but for $30 I can deal with replacing it if it fixes the problem.
I have good pressure at the rail at start-up, idle, and with throttle. The fuel pump is a brand new Ford 2100 pump.
85 CJ-7, 4.0L, twin stick/clocked flat Dana 300, SOA, 36" TSL's, 30/44 locked, Warn X8000i
92 XJ, 4.0L, AW4, Dropped NP231, 30/8.25, 4" DPG Hybrid lift, 33" MT/R's, JKS trackbar, JKS discos, OME Nitro Shocks, stinger bumper, Warn X8000i, etc. (work in progress)
CJHVN is offline
post #77 of 80 Old 10-07-2010, 09:42 AM
CJHVN
Update
Just a quick update. It's running like a champ now.
I rechecked that I was at TDC, reinstalled the distributor EXACTLY according to the FSM and it fired up perfectly and purrs like a kitten.
I can't tell you what the exact fix was, but I can only assume that I must have been a tooth off on the distributor or something.
Anyway, I now know more than I ever wanted to know about my 4.0L swap, distributor issues, and the wiring. I guess it's a good thing, but my brain is FULL!
Good luck to the rest of you on your swaps!
CJHVN is offline
post #78 of 80 Old 06-08-2013, 01:27 AM
Jeeper_YJ
What is the timing? I used a timing light and its 4* BTDC. I think its wrong. I think I read here its 14*? Am I off a tooth?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #79 of 80 Old 06-08-2013, 07:59 AM
CJHVN
I would go back to the first page of this thread and look closely at the distributor placement and timing procedure. That's what I did and it has worked for me. I wouldn't rely on the timing marks and/or timing light if your distributor or timing chain could be off or installed incorrectly.
CJHVN is offline
post #80 of 80 Old 06-08-2013, 08:54 AM
UZI4U
I haven't had a timing light for decades: http://www.classicinlines.com/Vacuum.asp
MCLMM
UZI4U is offline
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
3.8L Timing tbm5690 JK Wrangler Technical Forum 2 02-13-2009 12:12 AM
Timing on 4.2l Hampus YJ Wrangler Technical Forum 8 01-30-2009 10:38 AM
D.U.I. timing Reverb YJ Wrangler Technical Forum 3 12-26-2008 03:01 PM
Timing tonloc152 YJ Wrangler Technical Forum 2 01-02-2005 09:59 PM
