Time to throw the ol hardtop back on...seal questions - JeepForum.com
post #1 of 10 Old 10-22-2011, 09:59 AM Thread Starter
GAT72991
Hello all,
Well i'm about to get the hardtop back out. I plan on painting it, putting my monsta on my tub, and sealing it all up in one weekend. Just had a question on the seals.
My corner seals are fine, and i'm going to use weatherstripping from somewhere like Lowes on the tub area. But, where's the best place to buy the hard door seals from? I've searched and quadratec seems a little pricey, i may just bite the bullet though because it needs them bad.
Also, all my sheetmetal screws have stripped the windshield, i was looking at this:
http://www.quadratec.com/products/13022_00.htm
If i dont go with this kit, you guys have any other suggestions?
GAT72991 is offline
post #2 of 10 Old 10-22-2011, 10:08 AM
dodger889
I just bought large sheet metal screws( one size up) and not over tighten them. There is also pop nuts that could work too.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 10 Old 10-22-2011, 11:05 AM
BigDeaner
1987 YJ Wrangler
Probably not what you'de want to do if you're that concerned about fully sealing everything. My last 3 tops, I tried the larger screws each time, and eventually just ended up with holes too big to work with. I just took a small drill bit and drilled new holes a cpl inches over from each hole, use some smaller screws and have never had a problem. Don't notice leaks or drafts from the previous holes either. Hate looking at the old holes, but alot better than screws rattling out every 2 weeks. I know there is also a kit you can buy that will give you clamps like the tj, designed for the yj. Hope this helps.
***also..just noticed the kit you were referring to is the one i was thinking of, seems like it'de do the trick as well.
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
BigDeaner is offline
post #4 of 10 Old 10-22-2011, 04:37 PM
northernsimon
seals???? screws????
honestly, never had any seals between my tub and hardtop. nor any screws holding my hardtop to my windshield frame. sure she can be drafty........but if i can handle it in canada; south carolina should be very tolerable. heck, i doubt i'd even put my hard top on in SC...........................
northernsimon is offline
post #5 of 10 Old 10-22-2011, 07:16 PM
dodger889
here is a good way to fix those stripped out holes..
http://www.rivetsinstock.com/rivet-n...-k-series.html
post #6 of 10 Old 10-23-2011, 08:20 AM
jay-h
This has worked for me. The mounting holes over the windshield are very stretched out.
I got speednuts (sort of like this http://www.pointe-products.com/itemc...tal-Speed-Nuts) from Home Depot, but instead of putting them on the lip of the windshield, I used them backwards and put them on the lip of the hardtop and ran the screw through them. The screw passes through the hole on the windshield (keeping the top from moving) but does not actually engage threads any more on the windshield.
It's crude, but it does the job.
BTW while searching for a pic of this, I found a potentially useful site:
http://www.clipsandfasteners.com/?Click=2
jay-h is offline
post #7 of 10 Old 10-23-2011, 10:15 AM
UZI4U
Did you use these? If so, how are they holding up?
MCLMM
UZI4U is offline
post #8 of 10 Old 10-23-2011, 10:58 AM
dodger889
Have not tried them yet but from reading on here and other place they report back that they work.
post #9 of 10 Old 10-23-2011, 12:03 PM
JeepDrew_94
It can get pretty cold here in SC especially here in the upstate. I dont use any weather stripping with my hard top and its only attached with 6 bolts on the tub.
JeepDrew_94 is offline
post #10 of 10 Old 10-23-2011, 02:57 PM
GRYDE001
I don't use any screws on my windshield either. Only 6 bolts on the tub.
I got my hard door seals from the vendor on here a1 auto
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
2.5 rear main seal replacement and throw out bearing help makaioM3 YJ Wrangler Technical Forum 21 07-18-2013 09:19 PM
First time removing and then putting back hardtop BeachDriver YJ Wrangler Technical Forum 11 09-02-2010 07:27 PM
Front diff seal leak out the back. how do i fix the seal?? Mitchin TJ Wrangler Technical Forum 10 01-23-2010 10:14 AM
Hardtop Seal thyslip YJ Wrangler Technical Forum 5 11-17-2009 10:24 PM
questions on short throw shifter rytrac TJ Wrangler Technical Forum 2 08-13-2004 02:29 PM
