time to swap - JeepForum.com
post #1 of 12 Old 01-24-2010, 11:27 PM Thread Starter
swarrick308
time to swap
Went to Golers Gulch today and everything went well untill I was stomping threw water/mud puddels. All Of a sudden "Wham bang BAM" busted a U Joint at the rear axle (Dana35). Not so bad, I was 1/4 mile from HWY14 and was able to wire up the shaft and creep down the HWY in 4wheel drive(front only) untill my shaft fell out, not to worry nothing was hurt I was on the shoulder so it landed in the sand. I ended up calling a buddy and having him bring me out a Ujoint and hour and a half later it was fixed and I was on my way back to town. Went stright to the parts store bought two new joints and put them in my parts box in the back of the jeep. This brings me to the subject at hand. I have read and reread every post about 8.8's that there is. I have a 8.8 sitting in the garage waiting to be finished and put under the YJ. I want a Detroit but I am looking into a full spool. I live in the desert and it only gets driven to work about 8 miles away and back. Then there is the SYE and drive shaft, I am planning on a Tom Woods shaft and SYE kit. Is this a good deal or should I be looking else where? Then there is the rebuild kit, should I replace all the bearings and all hardwear? I am ready to get the 8.8 out of my garage and the D35 out of my Jeep. ANy help will help.
If you can read thank a teacher, if you can read in English thank a Veteran
swarrick308 is offline
post #2 of 12 Old 01-24-2010, 11:34 PM
ugmo
Lots of questions packed in there.
8.8 good
SYE good
Tom Woods good (might want to do the xj front shaft cut down for rear, though)
Detroit good
spool not good for dd
t/c rebuild depends on condition and mileage of t/c; I replaced my chain and fork pads, although they still seemed okay
ugmo is offline
post #3 of 12 Old 01-24-2010, 11:41 PM Thread Starter
swarrick308
Which SYE?
What is the "xj front shaft cut down for rear"
I am planing on rebuilding the t/c when I do the SYE.
Spool over Detroit for offroad?
post #4 of 12 Old 01-24-2010, 11:47 PM
ugmo
Originally Posted by swarrick308 View Post
Which SYE?
I went with an AA Sye and cut down an xj shaft. A search should give some tips on the xj shaft. I would not use a spool on the road, especially if you're driving 8 miles. By the way, there is no comparison between a spool and detroit. Detroit is a full carrier replacement, which means professional set up. If you want a cheap locker with road manners then get an aussie lunchbox.
If you're going to rebuild the t/c, then do not forget the chain and forks pads in the budget.
ugmo is offline
post #5 of 12 Old 01-25-2010, 12:13 AM Thread Starter
swarrick308
I like the reports on the aussie, they seam to be a great bang for the buck.
Where would be the best place to order from?
post #6 of 12 Old 01-25-2010, 12:46 AM
Late2jeepin
You can install the 8.8 and still use the same driveshaft that you used with the dana 35. You will need a adapther to the 8.8 flange. A sye would be nice, but if you are not lifted to much, not necessary.
Late2jeepin is offline
post #7 of 12 Old 01-25-2010, 09:53 AM Thread Starter
swarrick308
I am lifted 5-6 inches on 33's(soon to be 35's) but that is not the reason I want the SYE. I want it becuase when I bust a ujoint and dont have a replacement or worst tear up a drive shaft, I can remove it and still make it home in front wheel drive with out loosing all my fluid.
Does anybody have a link to the xj drive shaft convertion? My searchfoo is not up to par today.
post #8 of 12 Old 01-25-2010, 12:57 PM
dodger889
You just have to get a front xj front drive shaft ($40-50 or less from a junk yard) and have it cut down to fit the have a double cardine u joints on one end. Here is the only problem is finding a drive shaft shop to do the cutting and balancing.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #9 of 12 Old 01-25-2010, 04:31 PM Thread Starter
swarrick308
I am going to order the locker this week, but I am still strugling with which one. Spool/Aussie/Detriot- Spool upside- price, downside- daily driver. Detriot upside- bullet proof, downside- price. Aussie upside-price/durability downside- stock carrier.
HELP
post #10 of 12 Old 01-25-2010, 05:33 PM
RikRotorhead
Every Jeep emergency box should have one of these, even if you have an SYE. You can help a buddy that doesn't.
Mine is in the back of my son's t-case right now sitting on my garage floor. No leaks at all...
Cheap too!
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #11 of 12 Old 01-25-2010, 08:11 PM Thread Starter
swarrick308
That is a GREAT idea and I will have one in the jeep from now on.
post #12 of 12 Old 01-25-2010, 09:55 PM
RikRotorhead
They make great Christmas gifts for all your Jeep friends!
Buy in bulk and save!
RJC#512
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 01:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 07:12 PM
V8 swap time jeepncarl TJ Wrangler Technical Forum 16 09-05-2006 07:58 PM
engine swap time koeingsyj YJ Wrangler Technical Forum 2 06-12-2006 08:23 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 06:12 AM
