Is it time to "dump" this old money pit? - Page 2 - JeepForum.com
post #16 of 31 Old 04-03-2013, 04:31 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You can always just sign it over to me. I'm an idiot and will continue dumping money into a jeep with hopes it will eventually work correctly.
Luck Favours The Prepared
Anticanman is offline
post #17 of 31 Old 04-03-2013, 06:43 PM
pete1991YJ
Originally Posted by Rustyred View Post
I think it's mm. If they are stock (20+years old) ther're done. Mine looked ok till i replaced them and they fell apart.
X2 again, motor mounts...
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #18 of 31 Old 04-03-2013, 08:04 PM
linusb
Sounds like you'd be crazy to dump it!
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #19 of 31 Old 04-15-2013, 02:45 PM Thread Starter
lincolnmatthews
2015 JK Wrangler
Maybe I should have started another thrd, but thought I would add to this one, as I have started several on this *&^&&( Jeep!!
Had the SYE installed & I put in the Tom Woods drive shaft & raised the skidplate back into its original position. It seemed better on startup, & when pulling out of the driveway, but soon became apparent that its still the same old POS as before!! Can't drive it above 30MPH, very rough you can almost hear the roughness!. Anyway I haven't installed the Brown Dog MM yet, but can't hardly believe that they would take this all away. It also began to shift crappy between all the gears, (reblt AX15) a slight grind between all the gears. Tried going from 3rd to 4th with the pedal still partially disengaged & reved up the engine, seemed to be very rough. Probably doesn't mean anything though.
Decided to take it back to the trany shop & have them pull everthing out from the flywheel back to the rear end, just to go over everything again! & ( pay again!). Something's not right in the clutch,flywheel, or the trans.
I might also add that I bought a 95 skidplate & put it in, (kept everything for a 95 YJ) I am checking with the shop that did the actual conversion to get the part no's etc for the clutch, press plate etc that they used. Anyway can't quit now have to keep going. This is the problem when one uses two shops to perform this conversion, the trany people figure its the other shop, & vice-versa, anyway my own fault!, just no good Jeep shops around the area. Just "bend over" again, if & when I find the trouble I will sure & hell let everyone know! Just tried to do everything the right way & cut no corners, oh well!
lincolnmatthews is offline
post #20 of 31 Old 04-15-2013, 02:58 PM
soonermatt
I agree with the other people who are suggesting paragraphs.
I think you need to approach this one thing at a time and be willing to admit that part of the problem is your skill -- which you are here to fix.
You might have many issues which others will raise (your pinion angle might be bad, your CAD may be failing causing your front DS to spin, you might have bad tranny mounts, etc, etc, etc)
Take it slowly, write clearly and do lots of reading.
soonermatt is offline
post #21 of 31 Old 04-15-2013, 05:26 PM Thread Starter
lincolnmatthews
2015 JK Wrangler
Sorry about the lack of paragraphs! Due to the lack of internet service where we are now in the eves, I have to do it on my lunch 1/2 hr at work. Yes sometimes I get in a hurry when posting & get a little flustered, & notice that sometimes I'm hard to follow! For this I apologize! I will try to pay more attention to this next time! Thanks for the suggestions though
post #22 of 31 Old 04-15-2013, 10:05 PM
LordOfTheSith
Its a Jeep. I put almost nothing into mine for many years. I bought it new in 95. Even with light wheeling and neglect she has taken good care of me. Last year I had to put in a new rear end at 5 years that crappy ax tranny died but other than that she has been good to me. Last year I put new shocks and a new front bumper on her. I put in LED interior light (Blue)white gauges. This year she is getting nerf bars, Al Lined and new front seats. My point is if you love your Jeep and it takes care of you and is mechanically sound it is VERY worth fixing.
LordOfTheSith is offline
post #23 of 31 Old 04-16-2013, 12:35 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
If all esle fails, I'll fly up and take your rig home with me at no charge.
I called it first.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luuca is online now
post #24 of 31 Old 04-16-2013, 01:11 AM
YJrock88
I had the same vibration problem in my 88 and never thought that MM's would solve it , but it really did
YJrock88 is offline
post #25 of 31 Old 04-16-2013, 05:48 AM
Siva283
Did you reset your pinion angle after installing the sye and cv shaft?
Ask me how I know...
Siva283 is offline
post #26 of 31 Old 04-16-2013, 07:53 AM
Rproject
1987 YJ Wrangler
IMHO, if the frame and body are good, the mechanicals can get fixed. Cancer is the only reason for me to drop a Jeep.
As for the 87 being an "odd" year, I love my '87. Last of the AMC's. I'm more than relatively mechanically reclined under the hood and I've done more to my rig than I ever dreamed possible.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #27 of 31 Old 04-16-2013, 09:30 AM
bhartwell59
1987 YJ Wrangler
Originally Posted by lincolnmatthews View Post
At what point do you quite dumping $$$$ into the old YJ?
Haha... dig it brotha!
I haven't had to fix anything on my '87 for 4 weeks... I know something's about to "go"!
Did I just jinx myself?
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #28 of 31 Old 04-16-2013, 12:18 PM
Luuca
Luuca's Avatar
Yes. Yes you did.
YJOTM Sept. 2017
Luuca is online now
post #29 of 31 Old 04-16-2013, 03:31 PM
UZI4U
About the time you sell it, the next owner will need to sink in $100 and it will be tip top. You will never get to the point that you will be making a car payment. It may seem like it at times, but maintaining an old one costs less than paying for a new one.
MCLMM
UZI4U is offline
post #30 of 31 Old 04-17-2013, 01:03 PM Thread Starter
lincolnmatthews
2015 JK Wrangler
Well I hate to admit it but I finally had an enjoyable drive in my 87!! Yipee!! I put in some 4 degree shims & lined up the pinion better to the driveline. Made one heck of a difference! Not perfect but I could drive it at least. A little rough in 3rd & 4th on accel. but not decel. A noticeable inprovement
The new MM's go in Friday this I'm sure will also help. Here's my question: It needs to be shimmed some more, maybe another 2-4 degree's, I thought about machining away about 1/2 of the 1" TC drop spacers. This would give me about a 1/2" TC drop instead of the 1" that I had originally, (till I put in the SYE & T Woods drive line & moved the skid plate back to its original position). I think I could live with the 1/2" drop, would I gain much? or should I pull the shims & try to get some 8 degree or??
Would this be classed as "mickey mousing" it or is there really only one right way to do it?? Thanks again!
(Notice the paragraphs??) I thought everyone might be a little impressed!!?
