Time to do a v8 swap. What motor? Dodge 318/360 or a Ford 302? - JeepForum.com
post #1 of 30 Old 06-08-2013, 03:28 PM Thread Starter
uhohthe50
My tired 4.2 needs to go. I have terrible blow by, it smokes, leaks from the rear main and valve cover... its just a mess over all and it isn't worth it to me to try and save. Somehow it does just keep going though . I have been wanting to do a V8 swap for the past year or so and haven't had the time or money. I finally decided I need to just dive in and start piecing everything together for a v8 swap. I have been researching v8 swaps and can't decided on what to to. It's probably going to be a long process for me because I will have to buy the parts and piece everything together over time. Here is where I am so far:
1. Do I go fuel injected or carbed? I really want to do fuel injection and am leaning towards this. I'm not worried about figuring out the wiring for it. However, doing a carb swap seems like it will be much easier and cheaper. If it is going to be a significant cost difference I will just go the carb route.
2. If I go fuel injected what do I have to do to get my guages to work? In particular, my speedo is the old style mechanical and not a vss style.
3. I'm torn between the 302 and the 318 (or even a 360). I want to keep my ax-15 if possible to save some money and know I can get a bell housing off a a dakota if I go the 318 route. If I go the 302 route I know I can buy an adapter from novak or advance adaptors.
4. I'm kind of leaning towards a 318 if I can find one in a donor vehicle but I'm not familiar with those motors. What year motors should I look for if I go with a 318/360??
4. What should I expect to spend on a radiator? I probably won't worry about an electrical fan and try to keep the stock fan if possible. It sounds like I should expect to spend around $300 for a new radiator, but are there any radiators that I could keep from donor vehicle and adapt it to fit? I know it all depends on what motor I get, I'm just trying to figure out what I
Just like everyone else I'm trying to do this on a budget. I know I need to figure out what engine I want to put in before I can really get started with everything, so thats why I am asking for your help/opinions. I am not planning on buying a motor and rebuilding it. I just plan to find a good used, stock motor from a donor to put in.
I have been searching like crazy and am reading about other swaps from all over, so please don't just tell me to do a search. Any help is appreciated!
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #2 of 30 Old 06-08-2013, 07:01 PM
USMCBuckWild
Find an older Dakota R/T. 360, fuel injected and were available with a 5 speed trans. You get everythjng in 1 shot! I am pretty sure you can ge any Ram 1500/2500 with a 5.9/5 speed and use that bell housing as long as its a gas motor. I might be wrong.
Your speedo is mechanical, it is run off of your transfer case. Keep your case, keep your speedo the way it is. Change the case, you will have to change to the VSS, which isn't all that hard. Dakota digital and VDO both make kits.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #3 of 30 Old 06-08-2013, 07:11 PM
Jones-Maryland
I understand your dilemma. I started down the dodge road, I thought it might be easier since it is Chrysler, but wiring still needs to be done. I even picked up a Dakota bell housing. I went with a ford because I wanted the T19 fully synchronized trans. I did not want to chance the AX15 being near its limits with a 351, maybe, maybe not. Also there is a lot more after market support for Ford EFIs.
The other decision was OBDI (pre 95) or OBDII. I picked up a 95 351W the last year of OBDI, I don't know if it is easier to wire the OBDI but that is what I am using. Will have to get the novak adapter for the T19 to NP231. Also there are several companies that make engine brackets for the Ford. My decision of 302 or 351, well the old adage "there is no replacement for displacement".
I am with you on the radiator. There must be a cheaper solution than $500 for the novak radiator. If someone know this answer please chime in.
Until I get the setup mocked up in the jeep I won't know if I will have to change from the 351W truck intake to a car intake. The car intake is a lower profile but lose the longer runners of the truck intake, longer is torque. BC Bronco's makes an adapter for the truck lower to car upper that is still lower profile than the truck one.
If you go the Ford EFI route you also need to make a decision of Speed Density or Mass Air Flow EFI system. Go to Oldtimefuelinjection to get smart on the pros/cons/limitations of each.
Jones-Maryland is offline
post #4 of 30 Old 06-08-2013, 07:22 PM Thread Starter
uhohthe50
How old is "older"? I would love to be able to find a whole donor vehicle like that.
Now that I think about it.. the speedo question was a dumb question. I put an sye on my yj a little while back and I already knew that! I'm hoping to be able to keep my trans and transfer case for now since they are both in great shape.
post #5 of 30 Old 06-08-2013, 07:47 PM Thread Starter
uhohthe50
It seems like OBDI would be easier to work with. I am more familiar with ford motors so thats part of the reason why I am considering the 302. I would go with a mass air motor. Ideally I would want to get a HO 302 out of a 89 to 93 foxbody. I've been searching around but its hard to find exactly what I want.
At this point I think I will get whatever motor I can find the best deal on between the 302, 318, 360.
post #6 of 30 Old 06-08-2013, 08:38 PM
Plato2k5
I went with a mopar 360 la engine and put my own efi on using a standalone megasquirt ecu. I love the sound and power...though building them for power costs the most vs ford or chevy.
Plato2k5 is offline
post #7 of 30 Old 06-08-2013, 10:03 PM
czjeeper
Without a doubt, the Magnum is the easiest IMO.
Without a doubt, if I were to do it again and had the money, I would do a 5.3 or 6 liter Chevy.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #8 of 30 Old 06-08-2013, 10:25 PM
greyarea
I am going with a dodge 318 out of a 99 Ram. I am going with a carb to start out and get the mechanical bugs worked out then OBDII EFI later. I like the mopar v8 due to the only aftermarket parts that I am using are headers (could use pre magnum manifolds) and the motor mounts.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #9 of 30 Old 06-09-2013, 05:38 AM
USMCBuckWild
I built a stroker small block mopar and it was very expensive. I agree with you on running a 6.0, especially an all aluminum 6.0. Pure win right there! There are wirkng kits that require a 3 wire hookup to be turnkey.
I will always be a Mopar fan, but in some instances they aren't financially the best choice. Its totally up to the OP as to what he wants. Hell, a stock 440 would do amazing in a jeep if it wasn't so damned big!
post #10 of 30 Old 06-09-2013, 09:59 AM
Relicmoto
The Lincoln mark vii had a 5.0 ho. Same one that the mustang had on the inside, but with speed density. The conversion to mass air is straight forward and relatively cheap. At least cheaper. Where I live, I can buy an entire Lincoln as a donor car costs about the same as a 5.0 ho pulled from a mustang. Search speed density to mass air swap.
Relicmoto is offline
post #11 of 30 Old 06-09-2013, 10:02 AM Thread Starter
uhohthe50
Will do. I am going to look at a mustang motor today that I can hear run. Hopefully its a good one since its only about 15 mins from my house.
post #12 of 30 Old 06-09-2013, 10:03 AM Thread Starter
uhohthe50
Looks like a great build! What carb are you going with?
post #13 of 30 Old 06-09-2013, 05:16 PM
Specter1911
I vote the 302. Only because I like Fords. EFI will run better on any steep inclines you find yourself on.
Specter1911 is offline
post #14 of 30 Old 06-09-2013, 10:34 PM
Relicmoto
^what he said!
post #15 of 30 Old 06-10-2013, 06:13 AM
95YamJam
I am a gm motor fan so for me it would be my choice. You can find full donor vehicles pretty cheap and might not have to source as many seperate parts.
With that said I have had a few 302 s and they are great motors. I also like the Lincoln idea. I had a 88 mark 7. The motor was a beast. It never gave me issues. Lincoln's can be had cheap too because the mark7 was plauged by electrical issues and air susp problems none of which affect the engine.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
