tighten the E brake? - JeepForum.com
post #1 of 3 Old 05-19-2006, 07:42 PM Thread Starter
YJscott2
does any one have any info on how to tighen the E brake? anything will help
pics to.
its a dana 35 also
YJscott2 is offline
post #2 of 3 Old 05-19-2006, 07:56 PM
Bob_R
There is a "Y" under the driver side next to the frame rail. There is an adjusting nut on the end of the "Y". Make sure you have good shoes before you tighten up this adjusting nut.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #3 of 3 Old 05-19-2006, 08:17 PM
TellyDSP
Poland and PPV!!!!
THe nut on m adjuster was seized to the screw. Wound up removing the assembly and grinding the nut off. Put on a new one, and good to go.
Didnt work, but now that I rebuilt the brakes, it's back. Turns out worn shoes covered in fluid from a leaking wheel cylinder dont promote proper function.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
How To Tighten Emergency Brake Cable??? rastaangel TJ Wrangler Technical Forum 10 09-19-2009 03:07 PM
Tighten the nut? victoro TJ Wrangler Technical Forum 11 07-24-2009 09:03 PM
Is there any way to tighten a top? rebus20 TJ Wrangler Technical Forum 32 02-19-2009 04:14 PM
Tighten Parking Brake? DougieFresh JK Wrangler Technical Forum 20 06-12-2008 02:58 PM
Ok, Flame me, How do you tighten E-brake? JeepinYahoo TJ Wrangler Technical Forum 11 03-07-2007 05:18 PM
