Tie rod rubbing on axle cover problem - JeepForum.com
post #1 of 11 Old 09-06-2013, 05:45 PM Thread Starter
DennisD1990
I've recently put a g2 Dana 44 from axle of my jeep and have notice that my tie rod is rubbin up against the axle cover. What are some way to fix this issue I've though about grinding down the tie rod but I'm figuring that's probly not the best idea any advice on similar issues would be appreciated.
DennisD1990 is offline
post #2 of 11 Old 09-06-2013, 07:05 PM
Michaelgoesrawr
Offset tie rod ends.
Michaelgoesrawr is offline
post #3 of 11 Old 09-06-2013, 07:41 PM Thread Starter
DennisD1990
Will look into then thanks
post #4 of 11 Old 09-06-2013, 07:49 PM
jsawduste
2006 YJ Wrangler
RuffStuff has them
jsawduste is offline
post #5 of 11 Old 09-06-2013, 08:02 PM Thread Starter
DennisD1990
Thanks
post #6 of 11 Old 09-06-2013, 08:06 PM
Michaelgoesrawr
I'm pretty sure you need to get that kit as well as this
http://www.rustysoffroad.com/jeep-st...nd-thread.html
post #7 of 11 Old 09-06-2013, 08:36 PM
fratis
fratis's Avatar
BFH...If the diff housing cover is a standard stamped or welded steel unit then beat it with a sledge until it has a nice dimple in it. If it is cast in steel then take a grinder to the cover if it is hitting where the name plate is. You dont need that stupid thing anyways. If its rubbing up higher and not where the ribbing is you can probably still use the BFH technique. If you are worried about clearance between the cover and ring gear take some playdo and stick it on the inside of the cover and squish it back on. Remove cover and it will tell you how much room you have to play with. you could also get a regular stamped steel cover as well.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #8 of 11 Old 09-06-2013, 10:47 PM Thread Starter
DennisD1990
Cool yeah I'm look at them kits a little new but I agree bfh might be the deal its just rubbing on the cover part that makes the circle that has the g2 logo on the cover so I will check tomorrow and I might just do like u Sao and grind down the cover
post #9 of 11 Old 09-06-2013, 11:04 PM
jokerchief462
I had the same issue with a SOLID cover now it is a smooth no name cover. Pull it off and get your angle grinder out and give it hell. Then after you get the clearance get a front diff skid.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #10 of 11 Old 09-06-2013, 11:04 PM
fratis
fratis's Avatar
Yeah that's just decoration loose it.
fratis is offline
post #11 of 11 Old 09-06-2013, 11:26 PM Thread Starter
DennisD1990
Sounds like a plan
