Tie Rod roll fix! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Tie Rod roll fix!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim07-15 jeep JK Spare Tire Carrier Delete Plate
Unread 06-29-2015, 08:24 PM   #1
YnotJ92
Inexpensive tie Rod roll fix for OEM sized tie rod ends!
Ive been having the dreaded tie rod roll after my OME 2.5" lift, and I made a thread in which I set out to find what I could do to fix it http://www.jeepforum.com/forum/f12/h...wheel-3250385/. In this thread, a couple of members including bgredjeep told me about the Ruffstuff delrin tie rod end spacer which goes in between the drag link and tie rod to prevent the roll on 1-ton steering systems.
It seemed no one on this site knew of any options for stock size YJ rod ends... Which means that in order to prevent the tie rod roll, you would have to start looking into other types of rods/rod ends (that are usually hundreds of dollars) that would be less likely to roll than OEM.... Until now...
I emailed Ruffstuff to see if their aforementioned spacer called "The Cure" would work with stock YJ steering linkages, and a helpful gentleman named Kyle from Ruffstuff emailed me back with this: http://www.ruffstuffspecialties.com/catalog/R2008.html
This is another version of "The Cure" made specifically for OEM drag links/tie rods. Im not sure if any of you knew about this, but I sure didnt....
Now those of us with smaller lifts and OEM drag links/tie rods who experience tie rod roll have an inexpensive solution. This along with a drop pitman arm should render your tie rod roll nonexistent in my opinion. Im getting ready to order mine...
This also works with TJs, XJs, MJs, and 6cylinder ZJs according to their site.
YnotJ92 is online now   Reply With Quote Quick reply to this message
Unread 06-29-2015, 08:39 PM   #2
UZI4U
Post up when you get it...I'm definitely interested.
MCLMM
UZI4U is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 11:48 PM   #3
Unsteady
Guess they don't fit on the knuckles...I'm getting excessive roll there too.
Unsteady is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 12:06 AM   #4
YnotJ92
Me too, but from what I understand, if you stop the drag link from rolling, the tie rod in turn does not roll. The drag link rolling is what is causing the tie rod to roll.
Unread 06-30-2015, 12:40 AM   #5
Chrisnvegas
Chrisnvegas's Avatar
Why does mine not do this?
I have the same lift, plus 1/2" lift shackles too.
It's all stock steering and it has no "dead" spots or weird characteristics.
This post is not a "mines better than yours"
I still have the same OEM drag link. I am thinking about an XJ drag link, but I don't have any problems.
It's kinda weird.
What happens in my Jeep, stays in my Jeep
Chrisnvegas is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 01:09 AM   #6
Unsteady
Good to know. I bought all new TRE's anyway. We'll see how it goes.
Unread 06-30-2015, 05:28 AM   #7
bgredjeep
1987 YJ Wrangler
Nice. They just released this one I guess. Chris, are you sure you're not just used to it? I never had an issue with it myself (that's just how lifted YJs drive), but Amy didn't feel safe driving it with the slop.
bgredjeep is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 06:45 AM   #8
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
To me the only right fix is not have the drag link connected to the tie rod. Get a proper '2 arm knuckle' setup on the right.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 06:48 AM   #9
jserna
1987 YJ Wrangler
JRC offroad had the bushings that go in between the tie rod and steering knuckle.
jserna is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 07:54 AM   #10
jeepster93
I installed one of those things, the CURE, this weekend.
It replaced the dust boot on the tie rod end that is on the drag link to the passenger side tie rod end.
It worked.
I have a lot less slop in the steering wheel, more responsive.
I understand it only fits the 1 ton tie rod ends.
jeepster93 is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 08:20 AM   #11
Chrisnvegas
No, I'm not sure. I'll drive it and pay closer attention.
However, my wife, a complainaholic, has no complaints when diving the Jeep.
I'm suspective aftermarket TRE.
Mine are Mopar not Moog or Crown.
Unread 06-30-2015, 10:44 AM   #12
YnotJ92
It worked.
This does the same thing for OEM sized setups
Unread 06-30-2015, 12:01 PM   #13
superj
1987 YJ Wrangler
i am glad i saw this, mine does it too
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 06-30-2015, 02:04 PM   #14
YnotJ92
Yeah in the second to last email I recieved from Kyle over at Ruffstuff, he told me they just added it to the lineup.
Unread 06-30-2015, 04:35 PM   #15
RockWoRM
RockWoRM's Avatar
It worked.
Good to hear it worked out for ya... JCR sent me one when I did my 1 ton years ago. If squished out on the side and looked a lot like the slipped disc in my back! Only helped a little.
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
Originally Posted by 80 CHOPPER View Post
Knowledge is a tool, without knowledge, you are just a tool.
RockWoRM is offline   Reply With Quote Quick reply to this message
