Tie rod flip v/s dro pitman arm? - JeepForum.com
post #1 of 11 Old 03-08-2012, 12:47 PM Thread Starter
booboowv77
I recently installed bastard packs on my 89 yj, and had seen that most are not installing a drop pitman arm. Personally I think that something is needed to get the drag link a little more level because i have a good bit of bump steer.
So my question is if a tie rod flip kit would help? From looking at the front end it looks as if I would gain not only ground clearance but also it would help level out the drag link.
booboowv77 is offline
post #2 of 11 Old 03-08-2012, 01:23 PM
Louie4
Most guys with the tie rod flip use a stock pitman arm because a dropped would interfere with the tie rod when the drivers side suspension is compressed. I know that would be the case for me because my dropped pitman arm is already having a slight interference with the tie rod under full stuff on the drivers side.
The track bar doesn't having anything to do with the steering. I think you're referring to the drag link which, for our jeeps, connects the pitman arm to the tie rod. On other axles they attach to the knuckle.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 11 Old 03-08-2012, 04:38 PM Thread Starter
booboowv77
You would be correct, I did mean the Drag link. The track bar already went to the scrap yard haha!
post #4 of 11 Old 03-08-2012, 05:05 PM
Louie4
That's what I like to hear
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 11 Old 03-09-2012, 08:23 AM Thread Starter
booboowv77
Anybody ever done the Tie rod flip? How did it work out for you?
post #6 of 11 Old 03-09-2012, 08:44 AM
MLJeeper
MLJeeper's Avatar
Before
After
This was with the goferit inserts. No dropped pitman. Also has the Rustys steering conversion on it. but you get the idea.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #7 of 11 Old 03-09-2012, 09:24 AM
soonermatt
The tie rod flip is great and anyone with any lift should do it. It gets that bar up and out of the way. Just think about how offroading can get logs/rocks wedged down there and how this will get them slightly further from harm's way.
Mine has worked out great. As mentioned, it can be problematic with a dropped pitman arm. I have a dropped pitman arm and do get a slight collision when I flex out my suspension. It isn't anything bad.
I have just over 5" of suspension lift so dropped pitman arm and tie rod flip is great. My drag link is fairly level and I don't get any bump steer.
soonermatt is offline
post #8 of 11 Old 03-09-2012, 11:12 AM Thread Starter
booboowv77
Originally Posted by MLJeeper View Post
Before
After
Thanks that was what I was looking for. The pics showed me exactly what I needed. Mine is about the same as your before pic. I wasn't going to run both Flip and drop Pitman, I was just trying to figure the best way and I figured would help kill 2 birds (Tie rod Higher and Drag link closer to level) If anyone else has any thoughts on this please let me know. Thanks
post #9 of 11 Old 03-09-2012, 11:15 AM
MLJeeper
MLJeeper's Avatar
You can see where the drop pitman could cause issues after a TR flip. It easily gave me at least 2 additional inches of clearance.
MLJeeper is offline
post #10 of 11 Old 03-09-2012, 11:23 AM
moonshinefuel
A great mod. It just might not fit with factory rims because of the backspacing. But most have ditched the rims in favor of better spacing, better/ more suitable rims to accommodate larger tires, so the rim.clearance on the inside is not an issue mostly.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #11 of 11 Old 03-09-2012, 11:51 AM
richharr
Any threads or links on doing the tie rod flip? Getting a lot of junk when i search.
93 4.0l 5 spd, 33s 4" lift
1. This forum requires that you wait 60 seconds between posts. Please try again in 1 seconds.
richharr is offline
Poly Perf track bar kit and drag link (drop pitman or flip kit and your results??) premo JK Wrangler Technical Forum 30 03-17-2014 11:47 AM
Tie Rod Flip on D30 Jims-87YJ YJ Wrangler Technical Forum 14 10-12-2011 08:38 AM
Tie rod flip?? melius TJ Wrangler Technical Forum 8 03-30-2009 07:42 PM
Flip Top? Briznett YJ Wrangler Technical Forum 1 05-23-2003 07:15 AM
drop pitman arm and pitman from XJ bighair YJ Wrangler Technical Forum 4 05-28-2002 01:10 PM
