Tie rod flip and stretch Pitman arm interference - Page 4 - JeepForum.com
post #46 of 90 Old 05-01-2012, 04:57 PM Thread Starter
skyj
Ranger arm showed up looks like its going to work. I will have to remove my swaybar at full lock it will interfere with the draglink nut.
I still have to file the keyways but I test fit it and it gives just enough clearance. We shall see when the driver tire is at full stuff. Goferit inserts should be here Thursday.
From left to right, stock YJ , '91 2 wheel drive manual ranger (Got at local yard), '83 2 wheel drive power steering ranger.
build thread:
skyj is offline
post #47 of 90 Old 05-01-2012, 05:44 PM
Louie4
Good deal. Be sure to take a pic of the final product.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #48 of 90 Old 05-01-2012, 05:57 PM Thread Starter
skyj
Will do should be by this weekend!!!
build thread:
skyj is offline
post #49 of 90 Old 05-01-2012, 07:50 PM
fratis
fratis's Avatar
Perhaps you can try to find a shorter arm somewhere.
have to be careful as you can reduce steering radius with a short pitman.
Right now I got a bead on a Teraflex cross-over steering knuckle with 1.5" O.D. tie rod, and I'm unsure about the size of the drag link. It also has 1 ton TRE's.
the problem with that knuckle is the arm itself is too long and again reduces turning radius by quite a bit.
I may look at flipping the stock pitman arm and reaming it.
the splined section of pitman arms are tapered as well. flipping it wont work.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #50 of 90 Old 05-01-2012, 07:57 PM Thread Starter
skyj
Originally Posted by fratis
they are tapered. did you try flipping it?
The hole on the manual ranger arm is smaller than the power steering one. I got a power steering one and its only about a half inch shoter than stock YJ one I think I will be fine. I hope.
build thread:
skyj is offline
post #51 of 90 Old 05-01-2012, 08:39 PM
Louie4
Unfortunately I already have the knuckle so I'll just have to make due. For some reason I thought the splined section of the pitman arm wasn't tapered because the splines on the sector shaft is tapered. Either way I could just drill the arm through and put a heim joint on top and gain some clearance. Will see how it turns out and if I even need to go that route.
Lou
YJOTM July 2012
YJOTM February 2014
post #52 of 90 Old 05-01-2012, 11:09 PM
fratis
fratis's Avatar
the distance from the hole to the top ball joint is almost 9". my dana 60 arm is even shorter. some people have drilled their own hole in the arm of the knuckle and hacked off some of the length. for my funky front axle build i made my own pitman arm. ill be making another shortly and it will be my third. not hard to do.
fratis is offline
post #53 of 90 Old 05-02-2012, 07:46 PM Thread Starter
skyj
I need to go find a bigger stump.
Looks like it will all clear
Just need to order one more goferit insert I didn't think about the pitman arm its reamed bigger than the YJ tre. I tried to make the ranger tre work but the threads are bigger and won't fit the draglink. Unless I can think of something else?????
build thread:
skyj is offline
post #54 of 90 Old 05-03-2012, 01:32 PM Thread Starter
skyj
Just placed an order for one more Goferit insert. Hope it gets here as soon as the last one did. Now to focus on getting bumpstops in and building a real cage
build thread:
skyj is offline
post #55 of 90 Old 05-07-2012, 05:51 PM Thread Starter
skyj
I don't think that insert is coming out of the pitman arm.
forumrunner_20120507_174632.jpg Got it all back together and took it for a spin around the block. Works good can't wait to more road time in. Got to watch the kids so wife can have a break. More testing tomorrow!!
build thread:
skyj is offline
post #56 of 90 Old 05-11-2012, 09:08 PM Thread Starter
skyj
Tested it real good today towed my dirt bike with it for 80 miles and it did great. Steering is tight no binding. I also flexed it out real good out at my parents ranch and it
Has about 1" of clearance at full stuff with pitman arm drag link I'm real happy.
build thread:
skyj is offline
post #57 of 90 Old 05-12-2012, 09:47 AM
Louie4
That's great! I have my knuckle painted and will hopefully get to installing it next week depending on the weather.
Lou
YJOTM July 2012
YJOTM February 2014
post #58 of 90 Old 05-12-2012, 11:23 AM Thread Starter
skyj
Cool! I will be keeping an eye on your thread to see how it goes.
build thread:
skyj is offline
post #59 of 90 Old 05-30-2012, 09:10 PM
Louie4
skyj,
Looks like I may be going the route you went unless I find a flat arm from an Astro van or something.
Lou
YJOTM July 2012
YJOTM February 2014
post #60 of 90 Old 05-30-2012, 09:50 PM Thread Starter
skyj
skyj,
If you go with the ranger arm make sure its out of a 80's 2 wheel drive "power steering". I would go with the ranger arm over an astro, an astro will put your draglink behind your tie rod. I didn't lose any turning radius I can still go lock to lock. I guess with the tera knuckle you wouldnt have any interference with the two unlike my stock setup with the draglink attaching to the tie rod.
If you go with a flat arm will you have interference with the frame? The ranger arm has at least a half inch drop.
build thread:
skyj is offline
Poly Perf track bar kit and drag link (drop pitman or flip kit and your results??) premo JK Wrangler Technical Forum 30 03-17-2014 11:47 AM
Tie rod flip v/s dro pitman arm? booboowv77 YJ Wrangler Technical Forum 10 03-09-2012 11:51 AM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 07:44 PM
electric interference rinterr TJ Wrangler Technical Forum 6 03-01-2007 08:03 PM
anyone tried the clayton stretch kit or a custom stretch setup bluejeep2088 TJ Wrangler Technical Forum 5 02-01-2007 08:04 PM
