Tie rod and drag link - JeepForum.com
post #1 of 4 Old 08-11-2011, 01:35 PM Thread Starter
gotrock88
Does anyone know if the tie rod and drag link from a 98 cherokee will fit a 90 YJ? anything would help.
gotrock88 is offline
post #2 of 4 Old 08-11-2011, 03:25 PM
zman
It may fit but it is not the proper geometry and will probably hit the leafs. The tierod on a YJ is from knucke to knuckle, the Cherokee tie rod goes from the driver knucke to the draglink and the draglink connects the pass knuckle to pitman arm.
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #3 of 4 Old 08-12-2011, 03:05 PM Thread Starter
gotrock88
thats what I was afraid of. Thanx
post #4 of 4 Old 08-12-2011, 03:20 PM
jbeebe
x2. the ends fit in the knuckles, but the geometry of it is a downgrade compared to the yj. i was toying with the idea of putting a beefy tie rod from the V8 zj's in my yj, but with the geometry difference and the difference in the steering stabilizer location, i decided not too.
jbeebe is offline
Should my drag link be doing this? mightydog78 TJ Wrangler Technical Forum 8 02-09-2011 02:30 PM
drag link KingsOfTheSahara TJ Wrangler Technical Forum 5 07-09-2007 06:07 PM
drag link end TravisR YJ Wrangler Technical Forum 6 03-28-2006 09:51 PM
Drag link hits Swaybar link.... 5150 TJ Wrangler Technical Forum 12 07-21-2005 12:10 PM
V8 ZJ tie rod & drag link will it fit in a YJ?? Scubajeep YJ Wrangler Technical Forum 2 10-06-2003 03:29 PM
