Tie Rod & Currie 9" Problems - JeepForum.com
post #1 of 5 Old 08-01-2013, 03:48 PM Thread Starter
XM855
Here is my 89 YJ that's getting a Ford 302/NP435/NP205. I'm in the process of installing the front Currie 9" diff. I ran into a serious problem where the tie rod hits the pumpkin head and is going to prevent the knuckles from articulating back and forth.
http://s1332.photobucket.com/user/XM...tml?sort=3&o=0
What does everyone suggest I do? I'm thinking about having the tie rod professionally bent around the pumpkin head but I understand that it will have to be bent perfectly straight and also problems with shrink come into play.
Are there any other solutions to this problem? Please let me know what you think and I really appreciate it. I know that I am not the only one that has ever had this issue.
Thanks again!
XM855 is offline
post #2 of 5 Old 08-01-2013, 04:13 PM
rambo3489
First those shackles are hideous. No offense. Second I would return the tierod and make your own.
Grab a piece of 1.5" tube with .25" wall take it in have it bent to get around the diff throw some tube adapters on it slap some TRE's on it and your done.
Minor challenge to overcome. Sorry to say it but I foresee many more in your future.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 5 Old 08-01-2013, 04:44 PM
dillonjm
2013 WK
You'll have to build one that has bends near the ends to push the tie rod forward away from the cover.
Quite a few full size pickups have tie rods like this for the same reason. You could source one that way if you done want to custom bend one.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 5 Old 08-01-2013, 04:49 PM
kgcramer
1987 YJ Wrangler
Ruffstuff sells offset 1 ton TRE's that may help resolve your problem.
http://www.ruffstuffspecialties.com/catalog/STEER.html
kgcramer is offline
post #5 of 5 Old 08-01-2013, 04:49 PM
rambo3489
JK's have the same thing. But you don't want that puss assed stuff on your YJ
<a href="
THE YJ MY WAY</a>
