"ticking" bullshhhh...HELP!! - JeepForum.com
post #1 of 3 Old 06-21-2001, 03:47 AM Thread Starter
solid
I have an 89 yj w/ a 258. I recently replaced the hydraulic lifters and the rocker arm assembly but kept the original push rods. I replaced the lifters because I was getting a ticking noise during warm-up and occasionally during idle(disappears the moment I raise the engine speed). I don't get that noise anymore however I'm getting a different kind of ticking noise. The NEW noise comes on after about two minutes of driving and during acceleration, the moment I ease on the gas pedal the noise disappears. I don't get the noise when downshifting. When I rev the engine quickly, I could hear it a little bit. also the acceleration is great when the noise is not there, but it gets worse as the ticking starts to appear. The noise progressively gets louder. If I shut down the engine for about five minutes and then restart, the noise would disappear and then come back again after about two minutes.
Someone told me that it might be spark knock so here's what I did...
I switched to 92 octane
I decarbonized the combustion chamber with MOPAR combustion chamber cleaner
I adjusted the timing
I checked the EGR...its ok
I retorqued the manifold bolts...found one bolt loose
I'm not really sure if it's spark knock anymore...I don't even know exactly what spark knock sounds like
I need some advice...HELP!!!
solid is offline
post #2 of 3 Old 06-24-2001, 05:40 PM
hamyscj
Did you check for an exhaust leak? That is what it sounds like you are describing. Check you're exh manifold to headpipe connection. I have seen the manifolds crack also. An old trick to find these kinds of leaks is to dribble a few drops of auto trans fluid into the carb while the engine is running. This will produce a thick white smoke that should show where the leak is if one is present. It generally a good idea to do this with 2 people cuz the smoke won't last long. Good luck
One Way Up Racing
Romans 10:9
hamyscj is offline
post #3 of 3 Old 06-24-2001, 08:07 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
That does sound right. I had a cracked exhaust manifold on my K20 & it did the same thing. As the engine warms up, the crack widens and it gets louder. After cooling down, the noise goes away.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
Inline 6 making "ticking" noise when warm 06choppertj TJ Wrangler Technical Forum 18 09-07-2010 03:10 AM
Engine"ticking" after I shut it down. NHfireLJ YJ Wrangler Technical Forum 14 02-08-2010 07:28 PM
Ticking on startup and "Clunk" skiahh JK Wrangler Technical Forum 6 01-11-2010 05:00 PM
"ticking" noise when engine is running Nick12790 TJ Wrangler Technical Forum 12 12-11-2008 04:12 PM
"Ticking" Sound in Rear of Rubi?? rock2r TJ Wrangler Technical Forum 5 04-07-2005 11:49 AM
