Ticking from bellhousing???? - JeepForum.com
post #1 of 8 Old 12-16-2013, 06:41 PM Thread Starter
758879
1987 YJ Wrangler
hey my 87 yj 4.2 5 speed just developed a ticking noise recently. under loads 1st - 3rd gear it gets faster and louder and at idle i got out and it sounded like it was coming from the bellhousing i just put in a new clutch in 5000 miles ago. as soon as i hit 4th gear it goes away any ideas of what it could be also im having a terrible belt squeaking and replaced both belts could this possibly be a harmonic balancer too? id also like to note that ive been putting a lot of stress on the flywheel because it got cold out and my carb needed a rebuild so ive been really cranking on it the past month trying to get it to start in the cold any ideas?
I would support obama care if it covered my jeep too!
758879 is offline
post #2 of 8 Old 12-16-2013, 08:51 PM
Hotrodyj
Could be throw out bearing. I've had them bad right out of the box before
Hotrodyj is offline
post #3 of 8 Old 12-17-2013, 05:51 AM Thread Starter
758879
1987 YJ Wrangler
I dont think it could be throughout bearing because the clutch is fully disengaging and engaging and this throughout bearing is actually hydrolic so its like a piston and the piston while pop out and then ur screwed and wouldnt be able to move but i disregarded the clutch because the noise happens when u r in gear with the clutch engaged
758879 is offline
post #4 of 8 Old 12-17-2013, 06:00 AM
Hotrodyj
Yes mine is the same. But the actual bearings in the throw out will click if they are bad. I've had one lock up and the slave part of it still be good
Hotrodyj is offline
post #5 of 8 Old 12-17-2013, 06:03 AM
Hotrodyj
The throw out usually sits against the fingers of the pressure plate when the clutch is engage and foot off the pedal. When you step on the pedal it puts more pressure on the bearing and the noise will go away
Hotrodyj is offline
post #6 of 8 Old 12-17-2013, 06:30 AM Thread Starter
758879
1987 YJ Wrangler
I started it up this mprning and the ticking was still there but as soom as i got in and drove away it stopped and now i dont hear it anynore but last night i think it nade noise when i desengaged the clutch ill have to look for that thanks guys maybe it wont do it again maybe it will sounds like the culprit though
758879 is offline
post #7 of 8 Old 12-17-2013, 06:33 AM
MaddBones702
I had a bolt come out and it did similar things. Pulled the transmission out and there it sat in the bottom of the bellhousing. Worth looking at!
Who knew where this would go?
MaddBones702 is offline
post #8 of 8 Old 12-17-2013, 06:51 AM
Siva283
Another vote for the Throw out bearing. Mine is doing the same thing. Hopefully it makes it until spring. I dont wanna drop the trans in the snow
Ask me how I know...
Siva283 is offline
