Thunk sound when hitting bumps? - JeepForum.com
post #1 of 11 Old 03-10-2013, 12:13 PM Thread Starter
95yjJeeper
Hi all! I dont know much about anything outside the engine and transmission. So I thought Id get your opinions. When I hit a bigger bump, say coming out of my driveway to the street or rolling over a speedbump, I hear a thunking or klunking sound until I get past the bump(s) and on flat ground. What could be causing this issue?
Sent from my iPod touch using JeepForum
Paved Roads: Another great example of poor government spending.
95yjJeeper is offline
post #2 of 11 Old 03-10-2013, 12:15 PM
timatoe
timatoe's Avatar
That's pretty general. Where does it sound like the thunk is coming from? Could be bad motor mounts, could be the rear track bar, could be a variety of things, hard to say without a bit more specifics.
timatoe is offline
post #3 of 11 Old 03-10-2013, 12:18 PM Thread Starter
95yjJeeper
The thunk sounds like its coming from the front fender area
post #4 of 11 Old 03-10-2013, 12:19 PM
jeepyj13
Shocks are loosen up from mounts? That's my guess
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #5 of 11 Old 03-10-2013, 12:24 PM Thread Starter
95yjJeeper
I can feel the thunk under my feet when its happening though. Its kind of hard to explain. Lol It seems to happen if my front or rear wheels are uneven... For example one wheel on a rock and the other on the trail.
post #6 of 11 Old 03-10-2013, 01:10 PM
seattle_yj
Check trans mount and torque arm bushing. Tcase will hit the skid if these are worn.
Do you still have your track bar?
seattle_yj is offline
post #7 of 11 Old 03-10-2013, 06:15 PM Thread Starter
95yjJeeper
Yes
post #8 of 11 Old 03-10-2013, 06:41 PM
bum4x4
Check your ball joints. Mine was doing the same thing, ended up being bad ball joints.
bum4x4 is offline
post #9 of 11 Old 03-10-2013, 07:14 PM
bigbossd1030
When I busted my shock mount it did the same thing, felt it through the floor. Crawl under and give everything a shake see if anything it loose.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #10 of 11 Old 03-10-2013, 07:47 PM
seattle_yj
Yes
Might be loose and be bashing against the axle tube mount. give it a tug.
post #11 of 11 Old 03-10-2013, 07:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My guess is the track bar.
Luck Favours The Prepared
Anticanman is offline
