Thumb throttle on what side? - JeepForum.com
post #1 of 16 Old 12-01-2006, 01:12 PM Thread Starter
jeepster93
jeepster93's Avatar
This is not an earth shaking thread, but ....
I just installed a thumb throttle in my YJ. It works as it should.
MY question is...
What side of the shifter should it go?
Driver side?
Passenger side?
It causes the engine to rev, while on the pass side by being moved from front to the rear. Oppisite on the drivers side.
jeepster93 is offline
post #2 of 16 Old 12-01-2006, 01:25 PM
dadstoy
I think that would be a personal preference. I had mine on the passenger side.
dadstoy is offline
post #3 of 16 Old 12-01-2006, 01:32 PM
avh
As a thumb throttle I would think it would go on the driver's side so you could use your thumb. If not, you would have to use your pinky.
avh is offline
post #4 of 16 Old 12-01-2006, 01:42 PM
90yjkrawler
I would go with the drivers side and it would be kinda like an ATV throttle so you could use your thumb.
Until They All Come Home!
90yjkrawler is offline
post #5 of 16 Old 12-01-2006, 05:26 PM
Swampwalker3
1987 YJ Wrangler
Is it harder to drive with hand and thumb throttles?
It would seem to be for me, I don't picture them to be similar or as easy as the thumb throttle on ATVs.
Swampwalker3 is offline
post #6 of 16 Old 12-01-2006, 07:20 PM
84 400
does it act like a atv throttle or a boat throttle? if it is like a boat throttle inwould be fun for wheeling cause you could set the rmp's and just work the clutch on tough spots
84 400 is offline
post #7 of 16 Old 12-01-2006, 08:56 PM
jimaug87
i havnt seen that before. can you use the gas pedal or the thumb throttle or just the thumb now? if you installed it on one side could you move it? if so the i would try drivers side then passenger side to see whats better. if not im sorry but your on your own.
jimaug87 is offline
post #8 of 16 Old 12-01-2006, 09:48 PM
crosscheck17
i just installed mine. the problem with it on the driver's side is that it rotates the wrong way to be a "thumb" throttle. it would be more of an "index finger" throttle. so i just put it on the passenger side.
if it is installed the way it should be, both the gas pedal and hand throttle are functional. it would be hard to smoothly drive a stick using the hand throttle. i tried in my neighborhood and it didn't go very well.
"Flying is learning how to throw yourself at the ground and miss." - Douglas Adams
You laugh because I'm different. I laugh because I just farted.
"The box said 'Required Windows 95 or better'. So, I installed LINUX."
crosscheck17 is offline
post #9 of 16 Old 12-01-2006, 09:53 PM
dmcanally
dmcanally's Avatar
2011 JK Wrangler
are there any good how to's on installing a thumb throttle with pics? My only concern is how do you attach the cable to the throttle lever on a carb?
Red Jeep Club # 383
, _____
/l
,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
dmcanally is offline
post #10 of 16 Old 12-02-2006, 08:22 AM Thread Starter
jeepster93
jeepster93's Avatar
I will get pics of the connection to the tb(I don't have a carb), but it should still work for you. It will work by itself or with the gas pedal , made no difference here.
I got the thumb throttle from 4x4 toy store, as it is made for a Wrangler, with a stock like cable connection. Easy in, took 1/2 hour.
It seems easier to use on the passenger side, easier to get to...finger wise.
I installed the throttle mostly for my belt driven oba and to rev the engine during winching, but I can see it being useful on trail, as there are times when a manual trans, driver needs 3 feet to opperate all the pedals. Should help on the hiway too. Set it for 2000 rpm and go, go , go(poor mans cruise control )
I have yet to use on trail, the weather went bad here in Colorado, so perhaps next week...
post #11 of 16 Old 06-30-2011, 11:48 AM
BDurrant54
Which side is a personal preference. Thumb throttles are used for constant RPM as in for an onboard welder or for crawling when you just dont have enough feet for all the pedals. The trick to mounting it is to cereate a throttle linkage at the carb that can be defeated by the foot throttle when you climb out and start to use your foot throttle . then you return the thumb throttle back to idle. These are commonly used in places like Moab.
BDurrant54 is offline
post #12 of 16 Old 06-30-2011, 12:17 PM
GrantYJ
Personally, I like mine on the passenger side. I've had my homebrew hand throttles mounted everywhere from the cage to the dash to my shifter. The shifter seems to be by far the most convenient for the multi-pedally challenged. I've also got one getting ready to go under the hood for the OB Welder.
On a side note, it's not a great idea to use these things as a cruise control. If you want cruise control, that's great, but get a cruise control. In an emergency situation, it's doubtful that your first thought will be to disengage the hand throttle.
GrantYJ is offline
post #13 of 16 Old 06-30-2011, 05:38 PM
Tongie
MY question is...
Driver side?
Passenger side?
Personally, I like mine about 11 oclock on the gear shifter. I have found
that using my index finger while crawling feels the most natural.
Tongie is offline
post #14 of 16 Old 06-30-2011, 06:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Um.. Where did this thread come from? Did someone actually USE the search function to find it?
On a related note: Should the throttle cable be effected while shifting? Should there be more slack to avoid that?
Anticanman is offline
post #15 of 16 Old 06-30-2011, 09:17 PM
NHfireLJ
NHfireLJ's Avatar
What he said!!! Mine is the same...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
Hard Top Thumb Bolts rayzordee JK Wrangler Technical Forum 7 10-29-2007 12:08 PM
thumb throttles ryan188 TJ Wrangler Technical Forum 14 06-14-2007 10:38 AM
rule of thumb for airing down rmjuice9 TJ Wrangler Technical Forum 9 05-14-2007 06:37 AM
Different uses for the thumb throttle djaychris TJ Wrangler Technical Forum 29 11-07-2005 06:17 PM
hand/thumb throtle Negative6 TJ Wrangler Technical Forum 5 02-04-2005 08:29 PM
