Throwout bearing slave cylinder help really fast please - JeepForum.com
post #1 of 7 Old 01-19-2013, 03:16 PM Thread Starter
Carralo1
Hey guys, I'm midway through replacing internal slave and clutch in my 93 4.0. I can't find where the throwout bearing goes. There's no fork on the input shaft of tranny, just the slave was there. Wtf!! I don't know what to do please help.
Carralo1 is offline
post #2 of 7 Old 01-19-2013, 03:22 PM Thread Starter
Carralo1
Here's a pic of what I'm looking at....
http://s715.photobucket.com/albums/w...DB96080EB8.jpg
Carralo1 is offline
post #3 of 7 Old 01-19-2013, 06:45 PM
Mark05059
see the shiny thing where the slave is.. thats a throw out bearing.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 7 Old 01-19-2013, 07:12 PM
Berniebikes
yep, what Mark05059 said. Put the sucker back in your jeep! don't forget to replace the rubber grommet where the lines go thru the bell housing. those lines shouldn't be real loose and flopping around or it can cause a failure
Berniebikes is offline
post #5 of 7 Old 01-19-2013, 08:17 PM
az_zoner
I'm in the process of putting a slave in too and found a small piece of rubber in the bottom of the bell housing. When looking closer I saw that the seal on the front of the tranny was falling a part. So while your at it, buy the $3.99 seal and the $2.00 retainer gasket and replace it while you can. A 5 minute job.
Craig
az_zoner is offline
post #6 of 7 Old 01-19-2013, 08:34 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
How is this going for you now?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #7 of 7 Old 01-19-2013, 11:11 PM Thread Starter
Carralo1
Max
Well Everything went pretty smooth, I will be putting the transfer case back on in the morning and then start looking for a line at a local junkyard, not finding anything online. Thanks for takin the time to help earlier I really appreciate it.
Steve
Carralo1 is offline
