Throttle Position Sensor - JeepForum.com
post #1 of 5 Old 09-01-2011, 10:08 PM Thread Starter
brd90YJ
I tested my TPS today and it reads 5 volts in, 0 on the ground and it only reads about 1.8 at 4000 rpm. Does this mean that its bad or just needs adjusting?
brd90YJ is offline
post #2 of 5 Old 09-02-2011, 02:07 PM Thread Starter
brd90YJ
lets try again.
brd90YJ is offline
post #3 of 5 Old 09-06-2011, 11:47 AM
Que89YJ
Que89YJ is offline
post #4 of 5 Old 09-06-2011, 12:00 PM
GardenGnome5
From what I've heard you have to test them on the vehicle with the ignition in the "ON" position. Sticking the probes in the back side of the wiring harness. I could be wrong though.
GardenGnome5 is offline
post #5 of 5 Old 09-06-2011, 12:06 PM
Que89YJ
Yes, it does say that sort of in the post. Try this too:
http://www.jeepforum.com/forum/f12/3...l#post10542309
Que89YJ is offline
Throttle Position Sensor pgurt1 TJ Wrangler Technical Forum 56 11-24-2015 02:28 PM
throttle position sensor jlog TJ Wrangler Technical Forum 13 12-01-2013 07:36 AM
97 Throttle Position Sensor doubleup TJ Wrangler Technical Forum 6 12-18-2007 10:55 AM
throttle position sensor raven4640 TJ Wrangler Technical Forum 2 10-14-2007 12:24 PM
Throttle position sensor? ChiliPepperTJ TJ Wrangler Technical Forum 5 06-06-2003 04:27 PM
