throttle body issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > throttle body issues
Engo winches available at www.rockridge4wd.com! Free shippSwag Off Road BIG-HIT TJ-YJ Rear BumperCyber Sale on RUBICON EXPRESS - Short Arms, Long Arms, Tra
Unread 09-07-2013, 03:58 PM   #1
pinnick-46
hey guys, i have a 1990 yj with the 4.2l and a howell jp-1 throttle body on it, and i just replaced 90% of the wiring harness, and few other things, and when i was done, today i started it up and after running for a few minutes it started running decent, so i drove it a bit and parked it, and it wouldnt start again, and it looks like the throttle body is spraying the fuel in after i stop cranking the engine, and if i letr it sit for about a half hour itll catch and fire, and it has me rather stumped
pinnick-46 is offline   Reply With Quote
Unread 09-08-2013, 05:42 AM   #2
WDNewman
Sounds just like a weak crankshaft position sensor. Heat causes the weak ones to stop working, and the engine shuts down and won't restart. Let it sit awhile and cool down and it will restart. Just an idea.
WDNewman is offline   Reply With Quote
Unread 09-08-2013, 07:21 AM   #3
Old4X
1990 CJ7
Do a leakdown test on injectors
Rust free YJ for sale. Need more room in barn.
Old4X is offline   Reply With Quote
Unread 09-10-2013, 07:52 PM   #4
pinnick-46
Turns out the ecm wast getting power while the engine was cranking, only when the key was in run mode
