Throttle Body to Carburetor Conversion - Page 4 - JeepForum.com
post #46 of 51 Old 09-25-2011, 02:25 PM
superj
i am googling lost wax process. i have no idea what that is
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #47 of 51 Old 09-25-2011, 07:10 PM
Old4X
1990 CJ7
Lost wax is a process where you carve the desired item in wax. Then dip the wax carving in a ceramic solution and let that coating harden on the wax. The ceramic and wax is then fired in a kiln. The wax melts and runs out leaving a perfect mold of the desired part.
The mold is then used to accept the desired molten metal (aluminum, pot-metal, bronze, gold, etc) . After cooling, the ceramic shell is broken and removed from the finished product.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #48 of 51 Old 09-25-2011, 08:12 PM
Jax89Jeeper
Originally Posted by Old4X
How about just make a casting using the lost wax process? Wax is much easier to carve than a phenolic block.
Seriously, there are trade schools that do this and the cast part normally just needs final fitting and de-flashing.
Yes, the wax would be easy to carve, BUT.... The resulting casting would need more than just flash removal, there is a lot involved in making a correct casting. Material flow, cooling, and shrinkage need to be accounted for. The finished casting would then need to be machined in order to create an adequate seal on the sealing surfaces which makes it much more complicated than using phenolic. Phenolic is very hard, but can be shaped using common woodworking tools and techniques. If you start with the correct thickness of phenolic, the seal surfaces are already nice and smooth ready to seal up tightly. Metal casting is outside the capabilities and tooling of most DIYers.
Jax89Jeeper is offline
post #49 of 51 Old 09-26-2011, 02:00 PM
Flajeeper1
1987 YJ Wrangler
I'm going to suggest that if the wiring and a dead ECM are the only issues you have, you might see what jeep clubs are in your area. Someone in the club might be willing to help you resolve your issues (have beer available) and not have to go through changing to a carb. That said I have nuttered my 4.2 and changed to a Weber carb - runs great. Good luck which ever way you decide to go.
Flajeeper1 is offline
post #50 of 51 Old 11-04-2011, 08:50 PM Thread Starter
TexasTrue
Phase 2
I finally received my intake and got it installed. I have the carb in place. Anybody have any good diagrams of how to run the vacuum hoses? My Chilton's manual doesn't have the best diagrams and photos, and since it was previously fuel injected, I don't really have a reference point from before. Come to think of it, a good picture under your hood may be just as good as a diagram.
Thanks in advance.
TexasTrue is offline
post #51 of 51 Old 12-12-2011, 08:21 PM
mbates96
TexasTrue - how'd you make your adapter? Phenoic?
Anyone else - Anyone want to make/have an adpater? I don't really have any woodworking friends.
mbates96 is offline
carb , carb spacer , conversion , efi , throttle body
YJ throttle body conversion? Tuff01XJ YJ Wrangler Technical Forum 1 02-03-2011 09:52 PM
Throttle Body conversion cmb516 TJ Wrangler Technical Forum 2 07-24-2008 11:30 AM
throttle body conversion nightmare garym31 TJ Wrangler Technical Forum 1 11-17-2006 05:49 PM
4.0 Throttle Body Conversion JeepDrivr93 YJ Wrangler Technical Forum 2 10-12-2004 01:41 PM
Throttle Body Conversion important Q CanukYJ YJ Wrangler Technical Forum 22 09-22-2003 09:34 PM
