Throttle Body to Carburetor Conversion - Page 2 - JeepForum.com
post #16 of 51 Old 09-20-2011, 03:44 PM
04WJny
1987 YJ Wrangler
Originally Posted by goldeaglejeep View Post
So you wanna travel back in time to the times of carbs?
hahahahahah
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #17 of 51 Old 09-20-2011, 05:13 PM
4.7stroker
I used a fuel pump or the same year 4 banger. The 4 banger has FI with a intank pump. It is pretty much a straight swap.
If you have an intank pump already then just run the line from the tank to a return style fuel filter and hook up the return side of the filter to the return line. The pressure is not an issue because of the return.
The OP was not asking i anybody else would do this rather can HE do the swap and the answer is yes.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #18 of 51 Old 09-20-2011, 05:22 PM
superj
yup, he wasn't asking what ya'll would do. and if you want to run a lower pressure pump, you can order a basic holley from any auto parts store (and its probably in stock) for about 100 bucks. thats what i run on my 87 with a two barrel holley
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #19 of 51 Old 09-20-2011, 06:36 PM
Old4X
1990 CJ7
NAPA sells an electric fuel pump that works perfect, under $30.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #20 of 51 Old 09-20-2011, 07:01 PM
4.7stroker
I had problems running an external pump. I couldn't mount the pump low enough and the uel kept draining back to the tank and the pump was not strong enough to pull the fuel back up. Most electric pumps are designed to push fuel not pull it. I have been using the intank pump for about 8 months and the pressure is not an issue because of the return style filter.
I would just wire the pump to a source that is live with the ignition on and wire it through a oil pressure switch for safety.
The intank pump really is the best option IMHO.
Dwayne
[url]
[url]
post #21 of 51 Old 09-20-2011, 07:04 PM
superj
i used a check valve to stop the fuel from draining back and have my pump in the engine bay, by the cruise control unit
superj is offline
post #22 of 51 Old 09-20-2011, 08:15 PM
Old4X
1990 CJ7
This is a good way to do it.
Also, an elect pump on the frame rail will always be "wet" once primed, no way for it to drain back. Use it like you would a FI setup, and let the system prime for 5 sec before engaging the starter.
Old4X is offline
post #23 of 51 Old 09-20-2011, 08:18 PM
4.7stroker
I had nothing but trouble and still maintain the stock in tank pump that he already has with a fuel return is the best way to go. Why re-engineer something he already has that works fine?
Dwayne
[url]
[url]
post #24 of 51 Old 09-20-2011, 11:28 PM Thread Starter
TexasTrue
Thanks to all of you who have provided helpful answers. I'll post when I get her running.
TexasTrue is offline
post #25 of 51 Old 09-21-2011, 01:27 AM
Xpress
I for the life of me cannot see a justifiable reason to remove a fuel injection system in favor of a less powerful carbureted system... I would just stick my head in there and replace the fried wiring, but then again I love re-wiring stuff in the first place...
All about that unibody life.
Xpress is offline
post #26 of 51 Old 09-21-2011, 04:52 AM
superj
Dwayne
this is the most efficient way. i didn't have an in-tank pump so i had to do an external pump. and i couldn't mount it on the block like it should have been because my block is a 99 and doesn't have the spot any more to put a factory pump
superj is offline
post #27 of 51 Old 09-21-2011, 08:01 AM
roklok
I like it and have thought of doing the same thing. I did not think it was as simple as just replacing the distributor, intake, and bolting on a carb. I am old school and like to Keep It Simple Stupid (KISS).
1995 YJ, 4.0, 5 speed, hardtop, bone stock.
roklok is offline
post #28 of 51 Old 09-21-2011, 08:19 AM
mattlock1983
mattlock1983's Avatar
Dwayne
That statment in this thread is kinda ironic.
You DO realize that you are telling this to a guy who is putting a CARB on his FI engine, right?
(apparently, because fixing it correctly was too hard)
2004 Rubicon Artic Silver, Automatic
~2.5" Lift, LT285 MTR's, Currie HD steering, Currie Anti-Rock, Nth Oil Pan Skid, Kilby Steering Skid, Warn HS9500, Rockcrusher Diff covers, Nth Slider rear DS skid, custom bumpers, PIAA reverse lights, Tuffy Console, Uniden PC78 elite CB, Nth TT (not installed)
mattlock1983 is offline
post #29 of 51 Old 09-21-2011, 12:01 PM
Xpress
I wonder what kind of power losses you will get too. Just sayin...
Xpress is offline
post #30 of 51 Old 09-22-2011, 11:07 AM Thread Starter
TexasTrue
@ matlock1983 -
It has nothing to do with "fixing it the right way." So in your mind, anything that isn't OEM doesn't belong on a Jeep? Do you drive a stock Jeep without any modifications? NASCAR has been removing EFI off stock cars for years and replacing them with carburetors.
I chose to modify my jeep to a level that I was comfortable working on. I appreciate all your assistance in answering the question of is this possible. Oh wait, you just piped in with a smart comment to show off your superiority to me when it comes to all things mechanical.
carb , carb spacer , conversion , efi , throttle body
YJ throttle body conversion? Tuff01XJ YJ Wrangler Technical Forum 1 02-03-2011 09:52 PM
Throttle Body conversion cmb516 TJ Wrangler Technical Forum 2 07-24-2008 11:30 AM
throttle body conversion nightmare garym31 TJ Wrangler Technical Forum 1 11-17-2006 05:49 PM
4.0 Throttle Body Conversion JeepDrivr93 YJ Wrangler Technical Forum 2 10-12-2004 01:41 PM
Throttle Body Conversion important Q CanukYJ YJ Wrangler Technical Forum 22 09-22-2003 09:34 PM
