Throttle Body to Carburetor Conversion - JeepForum.com
post #1 of 51 Old 09-19-2011, 08:57 PM Thread Starter
TexasTrue
Has anyone ever removed the throttle body of a 4.0L YJ and replaced it with a Weber Carb? What spacer did you use? Will the intake manifold from a 4.2L CJ fit?
Here is one option I found. Can't tell if it will fit.
http://www.webercarbsdirect.com/100_550_p/100.550.htm
Someone please help before I set my Jeep on fire!
TexasTrue is offline
post #2 of 51 Old 09-19-2011, 09:11 PM
ja123182
huh??????why?????
ja123182 is offline
post #3 of 51 Old 09-19-2011, 09:52 PM
goldeaglejeep
So you wanna travel back in time to the times of carbs?
goldeaglejeep is offline
post #4 of 51 Old 09-19-2011, 09:56 PM
Tylerzap
Ive always hear Carb to FI, not the other way around.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #5 of 51 Old 09-19-2011, 10:03 PM
mazyj
This is why we cant have nice things...
On a serious note- I cant seem to think of a situation where this would be something anyone would want to do. Can you explain a little more about the situation and what your trying to accomplish or fix so we can help out?
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #6 of 51 Old 09-19-2011, 10:06 PM
4.7stroker
There is no reason you couldn't install a 4.2 intake and slap a carb on it.
I took a 99+ intake and with some modiications and a home brew adaptor I installed a MC2150.
Check out pics in my gallery for the conversion.
To some it seems like a backwards step but for me I need the simplicity it gives me. I do a lot of solo wheeling in the desert and the last thing I need is some sensor or wire failing leaving me with a long walk in the sun.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 51 Old 09-19-2011, 10:11 PM
goldeaglejeep
^ that's were I differ call me new school but we used to do 2hrs+ of rally runs and I felt very comfortable with a well tuned MPFI system.
post #8 of 51 Old 09-19-2011, 10:33 PM
Old4X
1990 CJ7
Your 4.2 or 258 intake will fit fine on the 4.0 head. But, you have to use the 4.o exhaust manifold with the 4.o head.
This is something I would likely do, I much prefer carbs over electronic wiz-bang squirt guns.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #9 of 51 Old 09-19-2011, 10:53 PM
imstillatwork
weird. I bought a horse to ride into town on the other day...They're mane is softer than a YJ and all they need is hey.
imstillatwork is offline
post #10 of 51 Old 09-19-2011, 11:09 PM
dillonjm
2013 WK
As others said, I can't think of one good reason to do this.
I love a good carb'd v8 as do many for their ease of tuning, but the FI 4.0 shouldn't need any tuning. Its a pretty simple system that works very well.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #11 of 51 Old 09-19-2011, 11:14 PM
94chb
i will give you all my 4.2 carb stuff for all your Fuel injection stuff!!! seriously ... i will ... i hate being carb and want to goto fuel injection.
94chb is offline
post #12 of 51 Old 09-20-2011, 12:17 AM Thread Starter
TexasTrue
Thanks for all the tips. Looks like I will be searching for a 4.2L intake manifold. For those of you forward thinkers, here is my reasoning:
My original wiring and ECM is fried. I bought the E-Z wiring harness, but, due to my superior electrical knowledge (insert sarcasm) I was unable to make the basic 12 circuit harness work with the computer. I decided instead to put an old style distributor and carburetor on to make her go. Also, I like the simplicity.
post #13 of 51 Old 09-20-2011, 12:23 AM Thread Starter
TexasTrue
PM me. Seriously. I'll send you my intake manifold and throttle body in exchange for your intake manifold.
post #14 of 51 Old 09-20-2011, 02:10 AM
mazyj
I applaud the originality, I would never think to do that
mazyj is offline
post #15 of 51 Old 09-20-2011, 03:22 PM Thread Starter
TexasTrue
old4x and 4.7stroker: Any suggestions on a replacement fuel pump? I'm hearing that I will need to tone it down to about 3-4 psi.
carb , carb spacer , conversion , efi , throttle body
YJ throttle body conversion? Tuff01XJ YJ Wrangler Technical Forum 1 02-03-2011 10:52 PM
Throttle Body conversion cmb516 TJ Wrangler Technical Forum 2 07-24-2008 12:30 PM
throttle body conversion nightmare garym31 TJ Wrangler Technical Forum 1 11-17-2006 06:49 PM
4.0 Throttle Body Conversion JeepDrivr93 YJ Wrangler Technical Forum 2 10-12-2004 02:41 PM
Throttle Body Conversion important Q CanukYJ YJ Wrangler Technical Forum 22 09-22-2003 10:34 PM
