THreads bad? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > THreads bad?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air locker
Unread 05-08-2005, 09:20 PM   #1
ohhpe
THreads bad?
I went to put my wheel back on and when i was putting a lug nut on i noticed it stopped halfway through.. so i looked at it and two of the threads appear to be smashed in... what should i do? i dont know how that happend, all i did was take the flat one off and put the donut on..
95 yj 6" lift, 34" truxs mts
2005 WK Limited 5.7L Hemi. 2" day star lift awaiting tires and wheels for installation.
ohhpe is offline   Reply With Quote
Unread 05-08-2005, 09:24 PM   #2
mlove6
u have three options starting with the easiest
1. U pick the best lug nut out of the bunch and run it on, most likely it will straighten out the threads and u wont have a problem
2. If u have a die u can run it over the threads and staighten them out for sure.
3. Knock the old stud out and throw a new one in.
if it were mine I would try the first option, if it doesnt work than u can cut the stud behind the lug nut, knock it out and install a new one, but most likely it will be fine.
mlove6 is offline   Reply With Quote
Unread 05-08-2005, 09:28 PM   #3
ohhpe
ok thanks... when you say "if it doesnt work.." do you mean if i cant just force it on there? im pretty sure i could probably just crank it on but i didnt know if that would fix it or be safe..
