thread tap question... - JeepForum.com
post #1 of 4 Old 07-30-2010, 09:30 AM Thread Starter
bluexj
I want to drill and tap some holes for 12-24 bolts. The tap says use drill bit #16.
What is a #16 drill bit and where to I get one? Is that a standard size?
bluexj is offline
post #2 of 4 Old 07-30-2010, 09:34 AM
EABiker
Yes, a number 16 drill is a standard size, (.1770), and should be available labled #16.
EABiker is offline
post #3 of 4 Old 07-30-2010, 09:35 AM Thread Starter
bluexj
Thanks! that was easy. I don't have a bit that size. Guess I'm going shopping today.
bluexj is offline
post #4 of 4 Old 07-30-2010, 09:38 AM
NateWithoutBeer
It doesn't have a fractional equivalent. It's somewhere between 5/32 and 11/64. You can either use a 5/32 and then go real slow and use lots of lube when you tap it (that's what I normally do) so as not to mess up your tap, or go look for a #16. We have hardware surplus stores around here that stock every size and shape of drill bit, you might look for the same in your area.
See this for details:
Drill Size Chart
Originally Posted by offshore View Post
So I totalled my 2005 Unlimited about 3 weeks ago, and now that I could find something that I really wanted I decided to go with a YJ. I loved my 04, but I wanted a real jeep
NateWithoutBeer is offline
Another TRE question thread... Painbow6 TJ Wrangler Technical Forum 8 04-02-2010 10:51 AM
TrackBar Thread Question chilijeep TJ Wrangler Technical Forum 4 02-07-2006 10:34 PM
1st post, thread, and shaking problem question... jermy82 YJ Wrangler Technical Forum 1 09-15-2005 05:19 PM
The End All Shock Question Thread/poll 97TJGUZZY TJ Wrangler Technical Forum 11 12-14-2003 04:47 PM
Question: wrench and thread sizes Jeff_Moersch TJ Wrangler Technical Forum 6 02-20-2003 08:15 AM
