Thoughts on Lights? - JeepForum.com
post #1 of 3 Old 02-21-2005, 03:35 AM Thread Starter
CosmicCreeper
Thoughts on Lights?
I was thinking of taking out the square lights and sealing that area up.
Or replacing the headlamps with fog or driving lights.
Then bolting these to the fenders as replacement head lights,
or vise versa:
Light specs:
Original equipment on Autocar
High/low beam headlight
Meets SAE/DOT headlamp specifications
Steel housing with chrome bezel
1/2" dia. adjustable ball stud
What you think?
USN Jeep Club Hull #1
CosmicCreeper is offline
post #2 of 3 Old 02-21-2005, 06:30 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Is there a problem with the regular headlights? Any body damage preventing the normal rectangular lights from fitting? If you are looking for a project because you are bored in the winter, how about cleaning up the engine intake or exhaust? Install a CB? Install on-board-air? Trim your spring u-bolts for more clearance?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #3 of 3 Old 02-21-2005, 11:15 AM
MuddyV8YJ
I personally think it is a terrible idea, but whatever floats your boat.
'91 YJ. Slightly Modified
'04 WJ. Columbia Edition 4.7 HO. 2" BB, 2" OME. 265/65/16 Icelander MT
MuddyV8YJ is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 06:33 AM
Thinking about side/rear fog lights, any thoughts? Kubiron TJ Wrangler Technical Forum 3 02-18-2009 10:18 PM
Area lights = Fog lights? Directional lights = driving lights? Marn TJ Wrangler Technical Forum 2 07-10-2006 02:46 AM
Switches, realys and lights...finally in..thoughts? USAFCOP TJ Wrangler Technical Forum 16 05-16-2006 04:13 PM
no lights, no lights, no lights !!!!!! {problem found} renegade0351 YJ Wrangler Technical Forum 10 03-06-2002 11:21 PM
