Thinking of Rhino Lining my heep - JeepForum.com
post #1 of 5 Old 08-29-2007, 02:07 PM Thread Starter
bryris
Could someone be so kind as to point me in the right direction on how to do this most correctly?
I've got a 95 YJ Sahara, completely stock. Its pretty much a mall crawler, but I'd like to protect the body as best I can from future rust and corrosion from water leaks, etc. The vehicle is not my main car, so I can afford the time to remove the carpet and seats, etc.
Is the actual application process difficult? Is it just a matter of brushing it on? What type of surface prep needs to be done?
I have a bit of rust on the driver side floor pan, but in the scheme of things, it is pretty minor. Also, there are a few drill holes under the rear seat where I can see light through down to the road. I think the previous owner had drilled in a sub or something. There is a touch of rust around the perimeter of these holes. What is the best way to treat those holes before lining over them?
bryris is offline
post #2 of 5 Old 08-29-2007, 02:21 PM
tuckinauster
tuckinauster's Avatar
search, theres tons of write ups on this
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #3 of 5 Old 08-29-2007, 02:21 PM
giggityjeeper
i used a wheel grinder and a wire brush after I stripped the inside clean, seats, carpet, everything, remove the drain plugs as well, then the stuff I used is simple, mix the 2 cans and roll on.....let dry done.
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 5 Old 08-29-2007, 02:32 PM Thread Starter
bryris
Search feature has been removed.
bryris is offline
post #5 of 5 Old 08-29-2007, 02:41 PM
jbolty
jbolty's Avatar
Unless you are a paying member:
Here's a taste:
http://www.jeepforum.com/forum/showt...ght=herculiner
jbolty is offline
Rhino Lining mean90yj YJ Wrangler Technical Forum 1 02-05-2007 09:33 AM
Rhino Lining ianschrd TJ Wrangler Technical Forum 7 01-26-2007 08:32 PM
Rhino Lining samger2 TJ Wrangler Technical Forum 5 10-27-2005 08:20 AM
Rhino Lining? Where? BamaRulz YJ Wrangler Technical Forum 8 02-23-2003 08:05 PM
Rhino Lining Dembones YJ Wrangler Technical Forum 10 02-20-2003 05:52 PM
