Thinkin a Weber - JeepForum.com
post #1 of 24 Old 04-03-2013, 08:58 AM Thread Starter
MCobb5
1987 YJ Wrangler
Thinkin a Weber
I currently have the issues with my stock Carter. It's been re-built 3 times and it never worked that good. So, I'm thinking a Weber, but currently undecided between 32/36 & 38. I've read a lot about these two carbs and since I live in FL, where it's flat woods and I don't need a lot of power, I am thinking about going with the 32/36. I found a carb on Webercarbdirect.com for $258.95 with no shipping cost.
http://www.webercarbsdirect.com/product_p/wk551.htm
Does this sound like a good deal or is there something missing? Most of the other places I look the webers were $300+ (Quadratec, 4wd, etc.).
Thanks!
MCobb5 is offline
post #2 of 24 Old 04-03-2013, 09:19 AM
flea1987
Get as much power as you can, never know when you might need it
flea1987 is offline
post #3 of 24 Old 04-03-2013, 09:23 AM
roadyrob
1987 YJ Wrangler
do a search here on the forum for weber carbs direct and read up. lots of complaints. they sell carbs licenced by weber but not actually made by them. the one you want is from redline weber. you can find it on ebay at a good price.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 24 Old 04-03-2013, 09:37 AM
jerresredyj
This is where I got mine. Runs great.
http://www.carburetion.com/Weber/Dat...20/%20CHEROKEE
jerresredyj is offline
post #5 of 24 Old 04-03-2013, 10:16 AM
roadyrob
1987 YJ Wrangler
^^^^^^^^^^^^^^^^^^^^ thats the one you want.
roadyrob is offline
post #6 of 24 Old 04-03-2013, 10:39 AM
Beachcruiser
1987 YJ Wrangler
Make sure you run a compatible fuel pressure regulator w/ that webber. They take less FP than our stock pumps put out.
probably out breaking stuff.
Beachcruiser is offline
post #7 of 24 Old 04-03-2013, 11:30 AM
jerresredyj
I bought a pressure regulator and never installed it. Haven't had any problems for about 2 years now.
post #8 of 24 Old 04-03-2013, 11:43 AM
Beachcruiser
1987 YJ Wrangler
Seems to vary a bit.
Maybe w/ altitude....got a buddy in Colorado that had fits w/ his until he put a regulator on.
post #9 of 24 Old 04-03-2013, 12:21 PM Thread Starter
MCobb5
1987 YJ Wrangler
Thanks!
MCobb5 is offline
post #10 of 24 Old 04-03-2013, 02:15 PM
Berniebikes
As a voice in the wilderness, have you considered fuel injection? You can put together a gm based throttle body injection system for about what it will cost you to buy the weber. For me, going to a weber was trading one set of issues for another. tuned, jetted, re-tuned and never got the thing set up well enough for my liking. It had lots of power across the range but couldn't get better than 13mpg. I finally pulled it off and put the fuel injection system on and haven't looked back. Now I have fuel delivery and ignition control no matter the altitude, no matter what incline I'm on, and consistently get better than 17 mpg around town. It starts cold, hot, or whenever and my gas smell is gone. Some folks just prefer a carb and if so then that's just fine. Just trying to suggest that isn't the only option.
Berniebikes is offline
post #11 of 24 Old 04-04-2013, 06:49 AM
blown50
1987 YJ Wrangler
I run the 32/36 on my stroker! They are very good carbs, but just like 99.9 percent of most aftermarket carbs, they are set up rich from the factory! It's better to err on the rich side than lean! Mine did require extensive tuning! But I do get 17-23 mpg out of it.
blown50 is offline
post #12 of 24 Old 04-04-2013, 07:26 AM
wanabejeeper
1987 YJ Wrangler
Can you expand on what you used and how?
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #13 of 24 Old 04-04-2013, 08:34 AM
rambo3489
Look into a MC 2100/2150. I can honestly say I have no complaints about mine. Great simple effective carb.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #14 of 24 Old 04-04-2013, 10:13 AM
Jax89Jeeper
+1 for the MC 2100/2150.
Much easier to get dialed in than the Weber carbs
Jax89Jeeper is offline
post #15 of 24 Old 04-04-2013, 11:07 AM
Old4X
1990 CJ7
If you are having continuing problems, have you ruled out other causes?
Timing chain slack under 6 degrees?
Proper idle manifold vacuum reading (21", more or less)?
Compression readings indicate healthy head and rings?
If any of these are off, you need to correct them before swapping parts.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
