think I got screwed - Page 2 - JeepForum.com
post #16 of 26 Old 02-16-2014, 12:47 PM Thread Starter
87duker
Correct
87duker is offline
post #17 of 26 Old 02-16-2014, 12:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by 87duker View Post
Then why doesn't make sense? 18 rocker height stock with 205/75/15 (27 inch tires). Before the lift had 31s and 2 inch body lift. That raise 4 inches to 22. But when I measured was 22.5. This springs look like new why I bought them. Supposedly put on 2 rigs but never finished
Did you measure it at 22" or did your math get you there?
Luck Favours The Prepared
Anticanman is offline
post #18 of 26 Old 02-16-2014, 01:19 PM Thread Starter
87duker
I did math but I was at 22.5 when I started this winter.
87duker is offline
post #19 of 26 Old 02-16-2014, 01:22 PM
Why J?
Why J?'s Avatar
I'll bet you had 1" lift springs and didn't realize it.
Anyhow, call BDS in the morning they will make it right.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #20 of 26 Old 02-16-2014, 01:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My math says you're an inch off. How tall is your body lift?
post #21 of 26 Old 02-16-2014, 01:32 PM
bpounds
bpounds's Avatar
If you had a "before" side view pic, we could probably guess at it.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #22 of 26 Old 02-16-2014, 01:34 PM
Hanger18
OP bought used springs & doesn't know what it was he replaced. What exactly is calling BDS going to do? Even if in the unlikely event that those springs are defective they are going to (politely)tell him to f#%$ off.
Hanger18 is offline
post #23 of 26 Old 02-16-2014, 01:46 PM Thread Starter
87duker
2 inch body. I know what I measured as I measured and put tape on window with number on it. Bds won't do anything since I bought used. Worried wreck shocks and 35s I ordered won't fit
87duker is offline
post #24 of 26 Old 02-16-2014, 02:10 PM
Why J?
Why J?'s Avatar
OP was able to get the BDS part number off his springs. BDS has a no questions asked lifetime warranty on all their parts.
BDS has a no questions asked warranty. They don't ask for a receipt. Call them.
My rig with 35's measures 25" at the rocker. I'm sure you have enough lift and have the 3.5" lift you bought. But if not call BDS they will make it right.
Why J? is offline
post #25 of 26 Old 02-16-2014, 02:12 PM
Why J?
Why J?'s Avatar
In fact when you put on the 35's you will have more lift than I do.
Why J? is offline
post #26 of 26 Old 02-17-2014, 10:10 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Let's get some better measurements to remove as many variables as we can. What is the distance between the top of the axle tube and the bottom of the frame? I'll run home and measure mine with BDS 3.5" springs and 5/8" shackles.
I'm at 10 1/8" from top of axle tube to frame.
Randonexplosion is offline
