think I got screwed - JeepForum.com
post #1 of 26 Old 02-16-2014, 11:41 AM Thread Starter
87duker
think I got screwed
I bought some bds 3.5 leaf springs. Well finally got them installed and jeep back on wheels. I gained 2 inches only. I based everything off the springs being what he said. They were next to new. Only thing I bought used out of 6 grand I invested this winter. Wondering should pull off and order new bds springs right size. My rocker was at 22.5 with 31st and 2 inch body lift. Now with lift and 3/4 shackles I'm at 24.5
87duker is offline
post #2 of 26 Old 02-16-2014, 12:03 PM
bpounds
bpounds's Avatar
Can you find a part number on the springs? That will tell you if the seller screwed you, or if it is just a fact of life on your Jeep. Estimating net lift is an inexact science but kit makers usually try to err on the low side.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #3 of 26 Old 02-16-2014, 12:12 PM
Why J?
Why J?'s Avatar
If your stock springs were sagging then the lifted springs will not yield 3.5" of lift.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #4 of 26 Old 02-16-2014, 12:14 PM
bpounds
bpounds's Avatar
Bass ackwards. He would have gained more lift than expected if the OEM springs were sagging more than expected.
Bill
post #5 of 26 Old 02-16-2014, 12:17 PM
Hanger18
Where the springs you took off stock or had a PO installed a lift/ helper springs?
Hanger18 is offline
post #6 of 26 Old 02-16-2014, 12:17 PM Thread Starter
87duker
004351 is number I found on springs
87duker is offline
post #7 of 26 Old 02-16-2014, 12:17 PM Thread Starter
87duker
No idea on what Po did. Rear track bar was removed though
87duker is offline
post #8 of 26 Old 02-16-2014, 12:19 PM
Hanger18
part # is right for a 3.5 lift spring.
Hanger18 is offline
post #9 of 26 Old 02-16-2014, 12:20 PM
Why J?
Why J?'s Avatar
That's right.
Why J? is offline
post #10 of 26 Old 02-16-2014, 12:21 PM
Why J?
Why J?'s Avatar
OP. Call BDS they will make it right.
Why J? is offline
post #11 of 26 Old 02-16-2014, 12:24 PM Thread Starter
87duker
Then why doesn't make sense? 18 rocker height stock with 205/75/15 (27 inch tires). Before the lift had 31s and 2 inch body lift. That raise 4 inches to 22. But when I measured was 22.5. This springs look like new why I bought them. Supposedly put on 2 rigs but never finished
87duker is offline
post #12 of 26 Old 02-16-2014, 12:27 PM
Why J?
Why J?'s Avatar
Do you still have the 2" body lift?
Why J? is offline
post #13 of 26 Old 02-16-2014, 12:39 PM
bpounds
bpounds's Avatar
Got info on the old springs? Part numbers? Leaf count? They may not have been OEM.
If those springs were 20 some years old, doubtful you would have had that much height.
Bill
post #14 of 26 Old 02-16-2014, 12:40 PM Thread Starter
87duker
Still have have body in and gave old springs away
87duker is offline
post #15 of 26 Old 02-16-2014, 12:44 PM
Why J?
Why J?'s Avatar
So the only changes are the springs?
22" with old spring. New springs you get 24.5".
Why J? is offline
