Thermostat Housing Spewing Coolant HELP - JeepForum.com
post #1 of 7 Old 05-16-2010, 12:07 PM Thread Starter
paxcrunner
SO i decided that I would change up the thermostat, easy enough. Well now i have gasket #2 on there and I thought it was fine, till it reached operating temp and not its literally spraying fluid out of the housing. I think it may have a crack in it? Ideas? I replaced all of the hoses and the thermostat. Where can i find a new housing for it? I dont even know what to take pictures of if you guys want to see, so please anything you can do.
paxcrunner is offline
post #2 of 7 Old 05-16-2010, 12:12 PM
monkeyhouse
You can buy that housing, look online, Napa has it and I think Autozone too. You can also upgrade to a high flow model, there's a thread on here with a pic of it, I found it when I replaced my system.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #3 of 7 Old 05-16-2010, 12:14 PM Thread Starter
paxcrunner
ok, found the crack.. so where can i find the new housing, because I cant find it online.
post #4 of 7 Old 05-16-2010, 12:16 PM Thread Starter
paxcrunner
ha, spoke too soon, thanks!
post #5 of 7 Old 05-16-2010, 12:22 PM
monkeyhouse
right here where I said:
Store Locator | NAPA Online
If the link doesn't work, just go to napaonline and select your vehicle and search thermostat housing.
post #6 of 7 Old 05-16-2010, 01:00 PM Thread Starter
paxcrunner
Monkeyhouse, thanks!
Now I'm wondering if you or someone can tell me wha exactly the hose that goes from me thermostat housing to the intake manifold is called, I went to napa and the guy couldn't find the part
post #7 of 7 Old 05-16-2010, 01:12 PM
monkeyhouse
Man, your napa guy stinks. I can walk into the local napa place and describe a part and this guy will find it. Here, I think the one you're talkin about is the third one down:
OEM Replacement Hoses and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH3
and here:
Cooling System Parts - Radiators, Water Pump, Fan, Radiator Hoses & Belts for Jeep Cherokee XJ by Morris4x4
or here:
Search Results - Quadratec
Small coolant leak around thermostat housing? I8AHUMR YJ Wrangler Technical Forum 11 04-08-2010 05:32 PM
Thermostat housing estropes TJ Wrangler Technical Forum 7 11-30-2008 07:26 PM
thermostat housing tcox TJ Wrangler Technical Forum 0 05-21-2008 09:09 PM
Coolant leak from thermostat housing UTWeezul TJ Wrangler Technical Forum 4 04-07-2007 09:43 PM
Thermostat Housing sequel YJ Wrangler Technical Forum 5 07-24-2004 12:00 AM
