Thermostat housing leaking - JeepForum.com
post #1 of 13 Old 05-31-2010, 03:09 PM Thread Starter
jeepster1976
I have a 1995 Wrangler 4 cyl. 2.5 liter automatic. I was replacing my thermostat and bought a new housing because the old one was corroded. When I put the new thermostat and housing on the engine and poured coolant in the radiator the thermostat housing leaks from the bottom bolt. I cleaned the old gasket and sealant material off of the engine and applied new permetex sealant on both sides of the new gasket. When I tightened the housing and filled the radiator with coolant, I still got the same leak. I also tried using ATV sealant, but got the same results. I tried tightening the bolt to stop the leaking, but I over torqued it and the bolt head snapped. I extracted the bolt and inspected the new housing I had bought. It looked like there may have been a crack in the housing near the leak area, so I returned it to Autozone. I took my replacement thermostat housing, coated the gasket, bolts, and bolt holes with permetex copper sealant, and still get the same leak from the bottom bolt area . Any ideas what I should do next?
jeepster1976 is offline
post #2 of 13 Old 05-31-2010, 03:54 PM
TSEJEEPERS
Not real sure on the 4 cylinders but if the thermostat sits at a angle alot of times it can drop down and keep the housing from sealing at the bottom.
Use a little RTV on the thermostat itself to hold it in place. It will keep it in place as you install the housing.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 13 Old 05-31-2010, 03:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sometimes things just don't seal up so well, and in those cases you could stand a little help.
Here is my "secret weapon" sealer:
(MFG description)
Permatex #3 Form-a-gasket Aviation Sealer
Non-hardening liquid gasket sealant/dressing/coating is a thin, brushable dressing or sealer for close-fitting parts. Suitable for continuous temperatures to 400F (204C). Resistant to antifreeze, aviation fuels, high-detergent oils and lubricants. Conforms to MIL-S-45180 D.
Permatex Aviation Form-A-Gasket No. 3
Read the list again, yep antifreeze is on there too! You can use it on T-stat housings & radiator hoses that prove to be difficult to seal up at the radiator, heater core, or water pump fittings. This stuff is amazing, it will seal up anything and without dealing with the goopy RTV that I despise so much and NO WAITING TIME!
Just use the "brush-in-can" lid and smear a thin film on both sealing surfaces & put them together & add the fluids/oils/etc. and be on your way. Use it on oil pans, valve covers, automatic tranny pans, case halves or anywhere. It's also a great thread sealer like for drain & fill plugs too. It's Aviation and MILSPEC certified.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 13 Old 06-04-2010, 04:31 PM Thread Starter
jeepster1976
Thanks for the tip TSEJEEPERS! That fixed the leak. However, now my engine seems to be running hotter than before even though I installed a brand new 3-core radiator, new heavy duty transmission cooler, new water pump, new thermostat, and new temp sensor. I burped it last night and I saw some funny results. I would see the temp gauge go up to about 215, drop very abruptly to about 130-150, and then rise again to about 215. This sequence repeated itself once more. I did get some permatex copper sealant spray on the temp sensor portion that makes contact with the water. any ideas of what's going on now? I haven't driven it on the street yet. Also, the top hose is hot after running the engine, so water is being circulated through the thermostat.
post #5 of 13 Old 06-04-2010, 04:38 PM
Mark05059
your seeing your thermostat working correctly...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 13 Old 06-04-2010, 05:35 PM Thread Starter
jeepster1976
I'm used to seeing the temp needle hold steady at a lower temp instead of jumping around
post #7 of 13 Old 06-04-2010, 05:49 PM
SpideYJeep
I replaced my waterpump and resealed my tstat housing about three weeks ago. My temp gauge fluctuated like that for about a week.
Make sure that you keep your overflow reservoir at the proper levels so that it can go through the burp and drink cycle as it is designed. Oh, check that the cap on the reservoir is tight.
Cheers!
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #8 of 13 Old 06-04-2010, 05:59 PM Thread Starter
jeepster1976
How much coolant should I pour in my overflow reservoir?
post #9 of 13 Old 06-04-2010, 06:05 PM
SpideYJeep
You should have level markers like your oil dipstick, "add" & "full", on the outside of the reservoir facing the cabin. keep it between there and you should be "cool"
post #10 of 13 Old 06-09-2010, 05:45 PM Thread Starter
jeepster1976
I have another problem, and I hope it's not serious. There's a small coolant leak from a valve cover bolt. This bolt is just above where the thermostat housing sits. What does this mean?
post #11 of 13 Old 06-09-2010, 06:01 PM
MJMPC
It might be leaking elsewhere and blowing back on the VC bolt.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 13 Old 06-10-2010, 07:50 AM
schwebel
I had to sand the crap outta my head on the housing area to get it to seal correctly. There was so much built up gunk around it, that it didn't seal the first time I replaced the housing. Make sure you have good mating surfaces. Also the housing is very soft aluminum (at least my replacement was) it is easy to over tighten and recrack the housing.
schwebel is offline
post #13 of 13 Old 06-10-2010, 08:45 AM
dgareysmith
1987 YJ Wrangler
I had the same problem and it is because the stock housing is very thin and warps under through the years of getting hot then cold. It usually doesn't cause you issues until you take it off. Then it won't seal back right. I went on Quadratec and got a replacement housing for $9. Never leaked again.
dgareysmith is offline
Thermostat housing estropes TJ Wrangler Technical Forum 7 11-30-2008 07:26 PM
thermostat housing tcox TJ Wrangler Technical Forum 0 05-21-2008 09:09 PM
Thermostat housing wont stop leaking manofmany TJ Wrangler Technical Forum 8 11-08-2007 10:58 AM
88 yj thermostat housing mshrmhd YJ Wrangler Technical Forum 6 11-24-2005 01:51 PM
Thermostat Housing sequel YJ Wrangler Technical Forum 5 07-24-2004 12:00 AM
