Thermostat - JeepForum.com
post #1 of 5 Old 06-01-2003, 08:06 AM Thread Starter
91YJoe
Thermostat
I have a '91 with the 2.5L, the temp runs 200-210 F.
Would I gain anything by putting a 180 thermostat
in it except maybe running 20 cooler,
would this change the performance any ?
Input appreciated. Thanks.
'91 YJ
91YJoe is offline
post #2 of 5 Old 06-01-2003, 09:15 AM
justincolumbo
justincolumbo's Avatar
no i run the same temp with a 91 4.0 it would be good just to do but i dont think any perfomance you will notice sorry. how much to do the job
justincolumbo is offline
post #3 of 5 Old 06-01-2003, 11:05 AM
BIG SEXY
BIG SEXY's Avatar
The times I have put the cooler t-stat in any of my vehicals, i have noticed more of a variation in temp.
Right now, your rig probably stays a 210* just about all the time right? Put the 180* in there and it will range from 170*-200*.
You will notice that it wont go to 180* and stay there.
Stick with what you got!!
91' YJ,4.0 I-6(180,000 mi) 2" Rancho Add-A-Leaf kit, 1.5" shackle lift, 2" BL, 33x12.50 BFG M/T KM's, 15x8 589's, TJ flares, custom F&R bumpers w/ swing-away spare carrier & rocker guards, FULL ROLL CAGE, herculiner, Warn XD9000i (IT'S ALSO MY WIFES... or was!!!)
Rig Rater score= 476RRv1.0
Its a dog-eat-dog world. and I'm wearing MILKBONE UNDERWEAR!!
BIG SEXY is offline
post #4 of 5 Old 06-01-2003, 11:20 AM Thread Starter
91YJoe
Your right it runs up to about 200-210 and stays there.
Forgot to mention I am running a flex-a-lite
electric fan behind the radiator, it makes it
drop to about 200 when it runs. Thanks.
'91 YJ
91YJoe is offline
post #5 of 5 Old 06-02-2003, 09:19 AM
gifargis
Pre warm up listens to the Coolant temp sensor and the
TPS and the MAP sensor
So it does have some sort of function being cold
but too cold will wear out the cylinder walls....
just my .02
See y'll on the trail.
gifargis is offline
What thermostat do I have? rihemi TJ Wrangler Technical Forum 7 12-18-2009 01:47 PM
Thermostat TimBrown TJ Wrangler Technical Forum 7 09-01-2009 09:17 AM
New Thermostat Black01TJ TJ Wrangler Technical Forum 11 07-13-2007 02:49 AM
Thermostat Glass TJ Wrangler Technical Forum 1 01-18-2005 03:26 PM
TJ Thermostat jsmjr1111 TJ Wrangler Technical Forum 1 12-22-2004 06:08 PM
