Is there a splash guard under the engine? - Page 3 - JeepForum.com
post #31 of 43 Old 09-29-2012, 01:54 PM
shockboss17
I just completed my splash quard, I used 1/4 inch think aluminum plate from Home Depot, it covers the alternator, n the underbelly, hopefully it hold up, let me know your comments. Not the prettyiest job but hopefully it will do
image-3029983261.jpg   image-1078426508.jpg   image-2725598230.jpg   image-4203022518.jpg
shockboss17 is offline
post #32 of 43 Old 10-30-2012, 01:09 PM
LeJerk
2009 JK Wrangler
Originally Posted by Feetwet View Post
Here's a quick sketch with rough dimensions.
Is it 20" by...?
LeJerk is offline
post #33 of 43 Old 01-30-2013, 07:24 AM
atldude
Wonder if something like this will work.. Mine is a little torn at the mounting holes:
http://www.amazon.com/gp/product/B00...TF8&psc=1&s=hi
atldude is offline
post #34 of 43 Old 01-30-2013, 01:31 PM
Jay-P
I guess if you could get it tight enough as to not become a wind catch if the front middle flops down.
1992 YJ + 2012 JKUR
Jay-P is offline
post #35 of 43 Old 01-30-2013, 04:27 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Looks like that stuff would work. A little thin, maybe.
The front connects to the crossmember right behind the radiator using nylon barbed pushpins, 4 of em I think. If you get em tight it shouldn't flop around too bad.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #36 of 43 Old 01-30-2013, 04:36 PM
atldude
Thanks guys. Was debating on 1/4 vs 1/8 in thick maybe 1/4 would hold up better. I think my oem is about 1/8 but a little less flexible than rubber. Thought abouta metal sheet but .. I think i'll stick to something a little more flex and without sharp edges. Would be real nice to have molded plastic aftermArket piece that bols on to the frame holes
atldude is offline
post #37 of 43 Old 03-27-2013, 09:07 AM
Alheim
That's funny Idso, I just had the oil pan off for a new gasket install. Popped out 2 dents and painted it with some shiny black rattlecan. Looks wet with oil though, doesn't it?
Anyway, took some measurements as promised. Here's a quick sketch with rough dimensions. Ignore the radiator location. I drew it in the wrong spot. It is actually in FRONT of the leading edge of the shield. The shield attaches to the cross member just behind the radiator, for you guys trying to fab up and install one. Just refer back to the earlier pics.
It installs using those plastic barbed push pins with the large round head. As I said earlier, I reinforced with wire here and there.
Hope this helps someone.
Awesome sketch. Thanks on behalf of The Internet.
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #38 of 43 Old 03-27-2013, 01:03 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
What, no love from the Library of Congress??
Thanks..
Feetwet is offline
post #39 of 43 Old 03-27-2013, 06:47 PM
Blackfish
mine was removed, when I used it for anger management trying to drill and tap a manifold bolt, I can tell you that was the best use for it. of course its always a good way to get rid of those loose tie raps laying around.
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
post #40 of 43 Old 07-15-2013, 02:09 PM
atldude
So i found the part available at vpartsinc.com part number for 2.5l '95 is 55174919 about $9 +$9 for shipping. This is cheaper for me than any other option simply cause i would have to buy the material whether it be rubber or alum/metal sheet. I just ordered so i'll let you guys know when it gets here.
Cheers!
atldude is offline
post #41 of 43 Old 07-17-2013, 01:58 PM
atldude
And it just arrived! Made in canada in 1998
atldude is offline
post #42 of 43 Old 07-17-2013, 02:02 PM
Brown Dog
Vendor
Brown Dog's Avatar
Does that fancy place mat come with it? If it does, I'm in!
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #43 of 43 Old 07-17-2013, 02:20 PM
atldude
Lol u get a set of 4! Pull the trigger
atldude is offline
Engine splash gaurd fell off roadkiller YJ Wrangler Technical Forum 9 04-09-2009 10:44 AM
Splash Guard for T&T Fenders BigDaddyChoice TJ Wrangler Technical Forum 8 05-25-2008 11:27 PM
Splash Guard Install Question Sky King TJ Wrangler Technical Forum 11 04-07-2007 09:23 AM
Splash gaurd for front of engine? terrible TJ Wrangler Technical Forum 1 01-01-2007 10:53 AM
Engine Bay Mud Guard gbean120 TJ Wrangler Technical Forum 3 08-01-2006 12:10 PM
