Is there any engine that can bolt in on stock mounts on a yj? - JeepForum.com
post #1 of 3 Old 08-01-2013, 08:51 PM Thread Starter
Jacoblytleyj
I was wondering if there's any engine that will bolt into stock mounts on my yj and if not whats the eisiest swap?
Jacoblytleyj is offline
post #2 of 3 Old 08-01-2013, 09:13 PM
SeanB95YJ
basically - no, without changing mounts you're stuck replacing with the same
as far as changing engines (I assume you'd want to go for more power) the easiest (but not the cheapest) would be to install a stroker, as it's basically a 4.0 with different internals. but there's no change (that I'm aware of) in motor mounts or wiring.
next easiest (and possibly cheaper than the stroker, depending on your source for engine) would be a carbed small block v8 (Chevy, Ford or Mopar).... for the most part, that's just a matter of changing the mounts, as there's really no wiring to worry about. This option though would make your YJ not "street legal" in most areas due to it wouldn't pass visual inspection for emissions requirements (that's up to you to find out for your specific area)
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 3 Old 08-01-2013, 09:40 PM Thread Starter
Jacoblytleyj
I was thinking of building a stroker with the 4.0 I got in it already and just buying a 4.2 liter for the parts. And I can swap it where I live cuz there's no emissions. I'm already running catless. If i was gonna swap it I would do a ford 302
Closed Thread
