Is there anothe vehicle that used the same rear glass struts? - JeepForum.com
post #1 of 8 Old 01-07-2011, 08:32 AM Thread Starter
Dentedvw
Is there another vehicle that used the same rear glass struts?
I have a YJ hardtop on my TJ because I bought it on accident, I modified it to fit, which it does, but poorly. The rear struts are pretty tired, it drops down to just about forehead level, which as you can imagine hurts when you run into it. I lost my job on Tuesday, which leaves me more time to work on the jeep, but obviously a lot less income.
Is there another vehicle that uses the same strut? Lots of junkyards around, but I don't know how to cross reference the strut. I thought maybe someone else had the same idea, and maybe knows the answer.
I like the CJ spring tubes, because they don't wear out and drop the window on your head.
I can only give you what I think you said you thought you wanted.
Dentedvw is offline
post #2 of 8 Old 01-07-2011, 10:37 AM
jeepin1995
jeepin1995's Avatar
just remove one of yours and take it to the junkyard with you. match it up with one there that is good.
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #3 of 8 Old 01-07-2011, 12:26 PM Thread Starter
Dentedvw
Might as well.
Dentedvw is offline
post #4 of 8 Old 01-07-2011, 12:40 PM
kingofkings
autozone or avanced or walmart sells the struts. usually only a few bucks to. they have a bunch of different sizes
kingofkings is offline
post #5 of 8 Old 01-07-2011, 04:37 PM Thread Starter
Dentedvw
I was at Autozone, they wanted about $28 per strut. That's a lot more than a few bucks! DOH! I didn't make it there today, spent too much time at the scrap steel yard. Hard not to, at $0.35/lb. Came home with about 150lbs. Oops. I plan to make a few bumpers, two will be mine, and the other I will sell to pay for the materials.
But, back to the struts.
I found a handful of them online, but the part numbers didn't seem to cross reference to any other vehicles. I will probably have to settle for something close, as long as it isn't longer.
Dentedvw is offline
post #6 of 8 Old 01-07-2011, 05:21 PM
letitloose06
I picked up some used lift struts at a bone yard a couple of years ago. They went bad in about 6 months. You can get a set of new ones from rockauto.com for about $25 shipped.
1992 YJ 4.0L, AX-15, 4" RE Standard Lift, 35x12.5R15 BFG KM2's, 8.8 Rear, HP30 front, 4.10's, SYE and CV Driveshaft, Taurus Electric Fan, 136 A GC Alternator, Grand Prix Seats, RR HD Steering, JCR Off road Stage 2 Front Bumper, Custom Rear Bumper
1966 M416 1/4 Ton Cargo Trailer --
letitloose06 is offline
post #7 of 8 Old 01-20-2011, 07:42 AM Thread Starter
Dentedvw
A follow up.
I spent an hour or so in the junkyard the other day, and found a set from an older Ford Windstar that were the right length, so I thought. Problem was, they didn't compress far enough, and they were really hard to close. I had to remove one, and even then, it was difficult. With both on, no way was it shutting. I guess the Ford tailgate is really heavy. Heh!
I am going to return them today.
I think there probably is nothing else close, I tried just about everything out there. I might try a few more, but will likely end up ordering new ones.
It was worth a shot.
Dentedvw is offline
post #8 of 8 Old 01-20-2011, 10:24 AM
jmmorgan82
2009 JK Wrangler
A little more than you wanted to spend, but here's a pair on Ebay
jmmorgan82 is offline
yj rear glass aaronm YJ Wrangler Technical Forum 1 11-01-2010 08:43 PM
Connector for Rear Glass Struts rymanrph TJ Wrangler Technical Forum 1 02-15-2010 01:35 PM
Lift Gate struts w/ rear defrost connectors? brc94yj YJ Wrangler Technical Forum 2 02-17-2009 08:19 AM
Rear glass dyna TJ Wrangler Technical Forum 3 10-11-2006 12:14 PM
Got a suprise today with my TJ, yet anothe problem (ahole invoked) Pkibugu TJ Wrangler Technical Forum 12 08-20-2003 10:09 PM
