Is there an "ACC" position on my YJ? - JeepForum.com
post #1 of 9 Old 02-25-2009, 04:31 PM Thread Starter
btwhite7
On my ignition, is there an accessory position? If there is I guess mine is broke because I have to turn mine to "on" to play the radio...
95 YJ Sahara
Bombs, Bu11ets, & Bl00d
btwhite7 is offline
post #2 of 9 Old 02-25-2009, 04:33 PM
01xjRubidog
mine turns one click backward for acc. i have a 94
"A banker is a fellow who lends you his umbrella when the sun is shining and wants it back the minute it begins to rain."-Mark Twain
01xjRubidog is offline
post #3 of 9 Old 02-25-2009, 04:37 PM Thread Starter
btwhite7
I might add mine is an auto tran
95 YJ Sahara
btwhite7 is offline
post #4 of 9 Old 02-25-2009, 04:51 PM Thread Starter
btwhite7
Yeah...if i tried to make mine go back 1 click I'd be cussin like a sailor with a broken key
95 YJ Sahara
btwhite7 is offline
post #5 of 9 Old 02-25-2009, 04:54 PM
Leans93
She's my density...
Leans93's Avatar
My 93' YJ is a manual transmission. It's one click back also. I really have to play with the key to get it to go though.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #6 of 9 Old 02-25-2009, 05:03 PM
befumo
Pretty sure 89, one click forward.
befumo is offline
post #7 of 9 Old 02-25-2009, 05:11 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Get some dry graphite powder in a small tube used to lube lock cylinders. You shoot a shot of that stuff into the keyhole and then work the lock some. The stuff is great and doesn't freeze in cold weather. Work on all locks even on combination safes mechanisms
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 9 Old 02-25-2009, 07:50 PM
jay-h
My 89 seems like it has a 'click' for acc, but it doesn't seem to be wired to anything.
Since I wanted the radio to be key operated, but playable with the engine off I set up a SPDT toggle. Normally the radio gets its power from the switched circuit, but I can throw the toggle and power the radio with the switch off.
It works.
jay-h is offline
post #9 of 9 Old 02-25-2009, 08:16 PM
barhall
Mine is one click back but for some reason it has to go forward then back before it works. Sometimes several times before I get power, it'll break some day.
barhall is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 12:54 PM
"#24 throttle position circuit out of range" ylojelo YJ Wrangler Technical Forum 6 09-14-2007 08:41 AM
Fan switch only works in "full" position BriJeep TJ Wrangler Technical Forum 1 01-31-2006 02:46 PM
Can't Get Hi-Lift in "UP" Position yurmom22 TJ Wrangler Technical Forum 5 02-22-2004 04:48 PM
Front Wipers don't speed up when on "Hi" Position Mr Ouija TJ Wrangler Technical Forum 1 02-11-2003 10:55 AM
