Is there 12VDC in accessory position - JeepForum.com
post #1 of 11 Old 05-09-2013, 02:27 PM Thread Starter
clhaggett
My 89 YJ has to have the key in the RUN position to play the good time radio. Is there any way to get 12VDC in the ACCY position? I can not find it anywhere, but every (or at least almost) vehicle I have owned allows the radio to be played with out the key in the RUN position.
clhaggett is offline
post #2 of 11 Old 05-09-2013, 02:31 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
My guess is that you'd have to find a circuit that has power in the run position and tap into that and power a relay that powers what you want.
Michaelgoesrawr is offline
post #3 of 11 Old 05-09-2013, 04:10 PM
atldude
Not sure if 89 is different but mine does play in run and acc both. Might be just hooked up diff than the stock by PO?
Should be able to trace the wires under the dash and see where it is. On mine there is also a fuse box under the driver side of the dash on the left that has wires to tap into that will do the trick for something like that.
atldude is offline
post #4 of 11 Old 05-13-2013, 03:10 AM Thread Starter
clhaggett
There must be a difference because I checked every point in the fuse box and found no accessory voltages. I only found constant and run voltages. Oh well, I can survive that.
post #5 of 11 Old 05-13-2013, 05:40 AM
roadyrob
1987 YJ Wrangler
my 87 radio plays in acc position.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #6 of 11 Old 05-13-2013, 06:02 AM
EABiker
My 89 has to be in run as well.
My lock cylinder is pretty worn out though!
EABiker is offline
post #7 of 11 Old 05-13-2013, 06:39 AM
grandboost98
My 89 works in either acc or run
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #8 of 11 Old 05-13-2013, 09:00 AM
wallydude
Check the ignition switch adjustment on the steering column. I had power to my radio in accessory position until I replaced the ignition switch. I haven't gotten around to messing with it yet so I can't confirm my hunch but I think I'm off just a little bit. Good luck.
wallydude is offline
post #9 of 11 Old 05-13-2013, 09:00 AM
Que89YJ
I bet it is an aftermarket radio and it has been rewired. Yes you should be able to play it in acc. position.
Que89YJ is offline
post #10 of 11 Old 05-13-2013, 03:09 PM Thread Starter
clhaggett
Thanks, but I have checked all the sources in the fuse box itself and no joy.
post #11 of 11 Old 05-13-2013, 03:09 PM Thread Starter
clhaggett
Thanks, good idea that I had not thought of.
