TFI Distributor Timing? - JeepForum.com
post #1 of 5 Old 12-02-2001, 06:20 PM Thread Starter
Brendan
I was talking to a guy about his weber and he said that once he got it one his jeep went out of timing twice in the next week (unrelated to the carb). I asked about this on this forum and everyone said that he didn't know what he was talking about. Then I was looking at the TFI juice box upgrade and it said that I would have to adjust my timing a little bit to get it to run perfectly. What are they talking about? I'm assuming a big name company on the internet isn't blowing smoke up my ***. I mean that info was tuning information. What is adjusting the timing. ANd how do you do it?
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 5 Old 12-03-2001, 07:59 AM
glm 87 wrangler
You will need a timming light you can get a cheap one off of JC whitney or maybe walmart
do not pay more than 20.00 bucks for it.
Mine is now set at 9 degrees btc you can play with it you may run better at 10 or lower just depends on your set up.Like carb or any other mods you may have added you will
know when you got it right.Just make sure your jeep is at opp.temp. Take it for a spin after you put it on let it get warm.190.Then set your timming count the slash marks on the
harmonic balancer.with timming light running
and turn your distributor lock it down check again you may have to turn right or left
to get at 9-12 degrees btc.I put the juice box on mine I love it!My timming is set at 9btc with a weber carb.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 5 Old 12-03-2001, 08:13 PM Thread Starter
Brendan
I'm sorry, but I still don't understand. I guess I'm just stupid. Are you changing the timing on the engine, meaning the cam vs crank? Or is this something on the distributor. Pretend you are trying to explain this to a girl.
Duvie
95 YJ 2.5L 5 Speed
Brendan is offline
post #4 of 5 Old 12-04-2001, 08:40 AM
glm 87 wrangler
Well there all happly tied in together.But for me to explain how to set I will go this route.Your distributor controls the timming of the spark to the cylinder.Every time the rotor turns past the sparkplug wire it sending a charge of electric current to the spark plugs.It all happens very fast look at your tac.0-6000rpms thats up to 6,000 times per minute.What you are doing is setting the timming of the spark to the cylinder.By doing this you will most likley
need a timming light.The distributor has a bolt on it.When you loosen it the distributor
will move right and left.That will help set your timming.Ok on your viewing point is the bottom pully.The big pully at the very bottom
If you look closely"you may have to turn it by hand or bump the engine over tell you see it"And maybe clean it off also".You will see the noch or line on the harmonic balancer.You should also see the scale it will have numbers or line marks If it has numbers it will be easyer but if it does not
you may have to count and guess,if it not right you will know it.Your timming light will connect to the #1 cylinder sparkplug wire very first one close to the radiator.The other 2 conectors plug on the batery RED+ black - With the ditributor bolt just loose enough to barely turn the distributor by hand and engine running at operating temperature.You may start. With the timming light pointed at the harmonic balancer the srobe will flash every time #1 hits.With the light fashing you will notice the notch it maybe off a little or a lot if its off alot then turn the distributor both ways slowly tell you find it.You may have to put the timming light down and walk to the side so not to get caught in the fan Or have someone to turn while you point the light.Once you have found this famous notch you can try to line it up to the scale 6to 8 or were it will run good. mine is set a 9 yours may run better at 8. On his TFI instructions he says 6 to 8 you can try that also. If you have a chilton or haynes manual it will better help you understand.Haynes being better for tune ups.After you get it set tighten the disributor bolt back down then recheck the timming to make sure you didnt move the distributor as you were tighting it. Then test drive and check for performance.if its not running right do it again tell its right.Sorry if this is choppy but kinda hard to explain on the internet...Hope this helps.
post #5 of 5 Old 12-04-2001, 11:22 AM
glm 87 wrangler
Oh almost forgot to tell you dont forget to plug your distributor vacuum advance on the distributor.While you are setting the timming
then put back on after complete.Do this agian
once you recheck to make sure it is still set.
Its the only vacuum hose going to the distributor.Plug it.
Distributor Timing Question Bridges31 YJ Wrangler Technical Forum 9 01-01-2010 01:43 AM
97 TJ timing/distributor setup for 4.0L TJ1997 TJ Wrangler Technical Forum 0 12-20-2009 05:42 PM
Timing/Distributor Issue Jeebs YJ Wrangler Technical Forum 2 10-18-2008 12:25 AM
Timing / distributor issue dmcanally YJ Wrangler Technical Forum 35 04-20-2008 09:15 PM
Timing/Distributor cap question FireMate YJ Wrangler Technical Forum 9 09-29-2004 02:36 PM
