TF999 Slipping! - JeepForum.com
post #1 of 9 Old 04-11-2010, 04:25 PM Thread Starter
shaggyjim
TF999 issues!
Hello Gents! OK I was on my way to work and about half way there I ended up with some slipping from the 999 shifting from 1st to 2nd and a bit from 2nd to 3rd. It was a rapid loss of motivation going from working fine to slipping. I was able to get to work and back to the house under power and it was the same with the trany hot or cold. Sooooooo.... Today I went out and did some tinkering on the jeep and let it idle to operating temp and checked the ATF even though I have no leaks on the ground. It was full, clean and still smelled ok. I had just changed the intermittint wiper switch a few days before and though I might have knocked the shift linkage out of adjustment so i readjusted that and still had the slipping. the slipping only happens as i go over 2000 or so RPMS and the engine get to the point that it would up shift however it wont. It slips and I lose some speed. I can run the RPM's up to about 3500 and take my foot off the gas and then the trany upshifts. Any thought gents?
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #2 of 9 Old 04-11-2010, 07:07 PM Thread Starter
shaggyjim
bump! Anyone have any ideas?
Jim...
post #3 of 9 Old 04-11-2010, 09:16 PM
beachedjeepyj
Check your throttle valve linkage before you drive it again, if it is out of adjustment it will cause hesitation or erratic shifting and eventually burn up your tranny.
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #4 of 9 Old 04-13-2010, 06:53 PM Thread Starter
shaggyjim
Thanks Beach I'll give it a try!
Jim...
post #5 of 9 Old 04-13-2010, 06:57 PM
BadAddetude
Look into adjusting the bands in the valve body. How many miles? I've used Lucas Transmission Fix with great success. Take some of your fluid out first!
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #6 of 9 Old 04-13-2010, 07:05 PM Thread Starter
shaggyjim
Well its got just around 183k on it now and it has been used kinda hard. I give the bands a look aswell thanks!
Jim...
post #7 of 9 Old 04-13-2010, 08:56 PM
fitbmxseries1
1987 YJ Wrangler
otherwise pick up a junk yard one. i found a few for under 300$ under 120k miles. check out car-part.com to see local yards.
fitbmxseries1 is offline
post #8 of 9 Old 04-22-2010, 04:58 PM Thread Starter
shaggyjim
Well it turns out my 2nd gear band broke and wouldn't ingage the drum anylonger.....
Jim...
post #9 of 9 Old 04-22-2010, 05:05 PM
notmyj
If all you need to do is replace the second gear band, its super easy to do at home. The band will prob cost about $15. The hardest part is pulling the tranny.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
CJ vs YJ TF999 VACJ5 YJ Wrangler Technical Forum 23 03-18-2010 08:49 PM
TF999 Rebuild VACJ5 YJ Wrangler Technical Forum 15 12-21-2009 06:13 AM
Will a AMC 318 fit onto TF999??? Kimoscout YJ Wrangler Technical Forum 4 04-13-2006 08:16 AM
Tf999 COJAM YJ Wrangler Technical Forum 0 11-16-2005 11:30 AM
Going from AX to TF999 what am I in for? BackRoadJPin YJ Wrangler Technical Forum 7 08-22-2005 10:47 AM
