tf999 problem - Page 3 - JeepForum.com
post #31 of 42 Old 08-08-2013, 07:46 PM Thread Starter
jr4x4
Originally Posted by jay-h View Post
When I finally decided to retire my 258 (after a long and successful life), I ordered an engine from Jasper and they were very particular about getting my serial number and matching a compatible one. Perhaps this is part of the reason. (I wouldn't have thought it that critical)
i agree. i thought u could pretty much put any year flexplate on a 4.2 so you can mach the tranny and it should be fine. he said the ringgear on this flexplate sits about a 1/4" in more (recessed) towards the engine than the old one. i guess that 1/4" was enough to put enough pressure to crack stuff. oh and a warning to anyone who needs a flexplate. beware 4 flexplates in a row from advance auto where bent in one spot. part numbet Z-187 from ATP.. thank you very much for your help. this forum has gotten me through so much ..
jr4x4 is offline
post #32 of 42 Old 08-10-2013, 05:55 PM Thread Starter
jr4x4
new update on clinking noise.
got my jeep from shop I bought the new 4.2 from today. started up and starter clunk was gone and so was noise. so as im driving home im feeling some vibrations. I pull over and look and these retarts put my transfer case drop back on wrong instead of between frame and cross member. they put cross member right up against frame and put bolt and spacer under it. so more or less bolt-spacer-cross member- frame. now I get home throw it in park and here the tink tink tink noise is again. what the hell is making this noise. so now 5 new flex plates new torque converter and $750 to shop to fix it. but didn't. im lost. im at my end with this jeep. what the hell is making this sound. its very clear metallic and right at bellhousing with a stethascope. I did notice I can slow it down to almost gone by turning my timing down to like 0 btdc or less. so I pulled my new cardone pre smog distributor out and droped in my old motorcraft 18r 13r dissy. thinking something is wrong with timing. nope. I did notice that there is no stop inside the vacuum canister of the motorcraft dizzy. no adjustment I guess. the allen key just slides all the way in. like its a open hole. (not sure if that is normal). any and all help would be great guys. thanks
jr4x4 is offline
post #33 of 42 Old 08-10-2013, 06:36 PM
jay-h
Maybe run it for a while, and see what develops. Have you tried removing the sheet metal cover plate?
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #34 of 42 Old 09-05-2013, 05:13 PM
CJ51973
CJ51973's Avatar
Anything new here. I have the same issue and wonder what fled plate to buy
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #35 of 42 Old 09-05-2013, 07:32 PM
superj
No info here. Mine was easy compared to this
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #36 of 42 Old 09-06-2013, 04:58 AM
CJ51973
CJ51973's Avatar
The only brand of flex plate I am seeing is ATP (NAPA has Balkamp, probably the same). Theat the same one that keeps breaking here so it worries me to buy one. Going used means I might get one about to crack. eBay also has a Pioneer brand but I don't see that anywhere else which doesn't instill confidence either.
CJ51973 is offline
post #37 of 42 Old 09-06-2013, 05:30 AM Thread Starter
jr4x4
88-90 4.2 flexplate part # Z-187 at advance auto
jr4x4 is offline
post #38 of 42 Old 09-06-2013, 06:06 AM
CJ51973
CJ51973's Avatar
Here are the options I can find for 1988-1990 4.2L after a bunch of looking:
Z-187 ATP
FRA-410 Pioneer
A310 MALKO
33004359 Crown (AMC number)
Last edited by CJ51973; 09-06-2013 at 10:13 AM. Reason: Venture doesn't sell this any more
CJ51973 is offline
post #39 of 42 Old 09-06-2013, 07:09 AM
superj
i guess don;t start with the atp one after reading the other pages in this thread
superj is offline
post #40 of 42 Old 09-09-2013, 06:01 AM
CJ51973
CJ51973's Avatar
So I emailed Golen (the guys that build big nasty stroker 4.2Ls) and asked what flex plates they used for a TF999. Crown was the answer with zero issues. I found them cheapest on JC Whitney for $60 shipped (free shipping and a 10% off code, ALERT49). Got one on the way. Probably tear it down after my 9/21 ride.
CJ51973 is offline
post #41 of 42 Old 12-04-2013, 03:27 PM
CJ51973
CJ51973's Avatar
The Crown worked great. No more knocking!
CJ51973 is offline
post #42 of 42 Old 12-04-2013, 07:34 PM
superj
Badass!! Glad you are good to go now
superj is offline
