Tf999 leak - Page 2 - JeepForum.com
post #16 of 27 Old 12-31-2013, 07:45 PM
JBTJ
Originally Posted by 102joe View Post
Great rite up thanks , wish I saw this a long time ago
Thank you, always wanting to help out my fellow JEEPERS.
JBTJ is offline
post #17 of 27 Old 01-15-2014, 12:31 PM Thread Starter
Gigemags05
1980 CJ7
Update:
So I pulled the pan and it is warped. I tried to flatten it out and put it back on, but there are two spots that I can't get completely flat.
I was looking around online and found a pan for $15 but its for a 32RH transmission. The pan looks exactly like the TF999 pan, and I know that the 32rh replaced the tf999. But I want to make completely sure before I buy the pan from the 32rh.
Also, does anyone know where else I might come across a pan for a TF999? The only things I can find online are deep pans and aftermarket options that are very expensive. Rock auto has one that they claim will work with the TF999 but its in a different shape when I look at the part number in google images.
Gigemags05 is offline
post #18 of 27 Old 01-15-2014, 12:43 PM
jbolty
jbolty's Avatar
This is the pan I got, 1 quart extra fluid. Comes with the filter and pickup extension
http://www.summitracing.com/parts/DCC-4007886AB/
jbolty is offline
post #19 of 27 Old 01-15-2014, 12:46 PM Thread Starter
Gigemags05
1980 CJ7
I saw that one, and may have to go ahead and bite the bullet and get it. But I was hoping to be able to get the one off of craigslist for free (plus shipping) if it will fit.
Question, though: Since the one you bought is a deeper pan, is there still room between the pan and the skid plate to get a wrench in there to loosen and tighten the screws? Or did you drop the skid plate?
post #20 of 27 Old 01-15-2014, 02:09 PM
jbolty
jbolty's Avatar
Plenty of room. I have a flat skid plus cut the transmission bracket an inch lower and the pan still just clears the skid. It would be easier the change with the skid out of the way though and if it's been leaking it might be good to clean the oil soaked sand out.
90% of pan leaks are from overtightening.
jbolty is offline
post #21 of 27 Old 01-15-2014, 09:13 PM Thread Starter
Gigemags05
1980 CJ7
Yeah I'm pretty sure mine was over tightened by whoever messed with it last.
Anyone know if the 32rh pan will work?
post #22 of 27 Old 01-16-2014, 02:45 AM
ChicagoYJ
Yes, I Understand!
ChicagoYJ's Avatar
Yes it will work. They are pretty much the same trans. The tf999 was renamed 32RH in 92, had to do with the torque convertor.
32RH History
In 1992, the TF999 received an electronic locking torque converter. This new arrangement was renamed the 32RH. The locking torque converter reduces operating temperatures, and increases fuel economy by eliminating slipping at higher speeds. The lower operating temperature prolongs the life of the transmission. The 32RH was used behind the 4.0L I-6 in the YJ, XJ, and TJ. The designation has a meaning behind it.
3 - number of speeds
2 - torque handling (2-300 ft-lbs)
R - rear wheel drive
H - hydraulically controlled
Specifications
Gear Ratio
1 2.74
2 1.54
3 1.00
R 2.20
Fluid Capacity: 8.55 quarts of ATF+4
Applications
Year Engine Model
'XX-'XX 4.0L I-6 XJ Cherokee
'92-'95 4.0L I-6 YJ Wrangler
'97-'02 4.0L I-6 TJ Wrangler
ChicagoYJ is offline
post #23 of 27 Old 01-16-2014, 11:18 AM Thread Starter
Gigemags05
1980 CJ7
Thank you for your response. That is what I thought.
I'll go ahead and get this pan, since its just about a $15 gamble. If it doesn't fit, then I'll get the one from Summit.
post #24 of 27 Old 01-16-2014, 11:34 AM
102joe
32RH History
Specifications
Gear Ratio
1 2.74
2 1.54
3 1.00
R 2.20
Applications
Year Engine Model
This should be in the stickys
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #25 of 27 Old 01-16-2014, 11:44 AM
jbolty
jbolty's Avatar
Good idea. Added to the FAQ
Now we can be sure no one will ever see it again.
jbolty is offline
post #26 of 27 Old 01-16-2014, 12:27 PM
102joe
R.o.F. L.
102joe is offline
post #27 of 27 Old 01-16-2014, 01:25 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Haha. I am a sticky skipper on most forum but the FAQ here I use very often.
Saved me a ton of post and wait time
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
