Tf999 - JeepForum.com
post #1 of 11 Old 05-27-2013, 05:59 PM Thread Starter
SLCSmoker
Tf999
Well it seems I've sealed most of the engine oil leaks (pan, rear main etc) now I just have a tranny leak... For the sake of speed I was going to pick up a junkyard tranny, service it and swap it out for the leaky one. Does the 'right' TF999 come on anything else apart from a YJ and are they a straight swap?
Help much appreciated!
SLCSmoker is offline
post #2 of 11 Old 05-27-2013, 08:21 PM
superj
If you have the 4.2, I think you can use the one froma cj also but that tf999 is also known by another number, tf727 or 777, something like that
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 11 Old 05-27-2013, 08:32 PM
jeeepguy
jeeepguy's Avatar
TF999 is the same as the 32RH but it is computer controlled. The TF999 is exclusive to Jeep from 1991 to 2001
All TF999 are a straight swap.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #4 of 11 Old 05-27-2013, 10:43 PM
deathtrap
It comes down to bell housing pattern. they were used in a LOT of mopars, but you need one from a inline 6 cyl. jeep.
deathtrap is offline
post #5 of 11 Old 05-28-2013, 10:20 AM
superj
didn;t they use them in the amc cars also, and the international scouts and pick ups?
superj is offline
post #6 of 11 Old 05-28-2013, 10:43 AM
ninjakid
1987 YJ Wrangler
TF999's came in cjs as well and are identical.
Shift linkage is different so you'd need the original.
Get the mopar pan gasket for it.
Its a thick rubber covered metal gasket and its far better than a cork gasket.
Incompetence in motion
96 XJ 4dr, 4.0, AW4, NP231,
87 Wrangler, 4.2, TF999, NP231
ninjakid is offline
post #7 of 11 Old 05-30-2013, 06:38 PM Thread Starter
SLCSmoker
So any Wrangler up to 2001 or CJ with an auto is the same?
Going to have it rebuilt and swap out the leaky one.
And Yes its a 4.2...
post #8 of 11 Old 05-30-2013, 06:59 PM
jeeepguy
jeeepguy's Avatar
'87 to '95 trannies are the simplest to exchange. Plug in and go.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #9 of 11 Old 05-30-2013, 08:20 PM
flashy
If you are taking it out you might as well upgrade...Aw4 from a Cherokee. I just bolted one up and it was straight toward. Pros. Same gear pattern plus overdrive, they are everywhere, reliable. Cons. Slight modifications needed. Just a thought.
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #10 of 11 Old 05-31-2013, 04:54 AM
superj
what mods? i read it was actually a fair bit of work to swap a cherokee automatic into our jeeps?
superj is offline
post #11 of 11 Old 05-31-2013, 07:43 AM Thread Starter
SLCSmoker
I don't mind the tranny, it just leaks and I don't fancy having the YJ sat while the tranny gets refurbed. Plus its always nice to have a spare!
87 to 95 it is, I'll go find one.
